11 sec
Old Dec 12, 2004 | 05:58 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
11 sec
I was just woundering how much hp. you would need to get in the 11's beacuse i am going to start an engine build next year after i get the suspension and all the other things done to the car here is what i have so far a/c smog delete hooker shorty's. lakewood 50/50 shocks and 90/10 struts i'll be putting 4.10 gears in it soon and beefing the 10 bolt up a little more. got alot of weight off the car. what should i go with 383,350,355 thanks
Old Dec 12, 2004 | 06:51 PM
ljnowell's Avatar
A 350 and a 355 are the same engine, just like the 357. The last two are nothing more than a 350 block that has had maintenance to ensure proper function. If you want 11's NA, cubic inches are going to be your friend. The smaller the displacement, the more radical the engine will have to be. Basically, the smaller the displacement, the less streetable, or worse manners. A 383 would be easier to achieve the goal, but a 350 can make it without a problem at all. How radical do you want to be? What kind of trans is going to back this?
Old Dec 12, 2004 | 07:15 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I did it with less than 400 rwhp and a full weight car on street tires and a 342 rear gear....
Old Dec 12, 2004 | 07:56 PM
Car: 1987 iroc z
i was thinking keep the 700r4 or would it be better to get a 350 or 400 would the 700r4 be able to handel 450hp what could i do to make it handle the power. i was going to go to the super chevy show next year and just get a used 350 and build it from the ground up. since its not till june i'll have time to get the rest of my car done then start on the engine.
Old Dec 12, 2004 | 09:15 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
1/4 ET is really about torque, traction and weight.
Next season my goal is to run 130+ mph, dont really care about ET. Well, as long as I don't get kicked out for lack of roll cage! hah
-- Joe
Old Dec 12, 2004 | 10:46 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
375 hp or so, and the right suspension, and a good torque curve. Buddy went low 12s and should have hit 11s, but his tranny gave out on his best pass. He put down 370 hp and 360 tq. W/ the right suspension and converter it will go...
Old Dec 13, 2004 | 04:32 AM
ede's Avatar
ede
lot depends on weight and traction
Fanatic1074
Oct 3, 2022 05:57 AM
rb85TA
26
Sep 14, 2015 10:29 PM
IROCZ1989
Sep 4, 2015 11:54 AM
EFR2000
Aug 18, 2015 08:54 PM
Winchester1094
Aug 18, 2015 10:23 AM
