will start but wont stay running at all
Old Dec 13, 2004 | 05:13 PM
seanjuan's Avatar
Car: 1981 monte carlo/sold 1984 z28
Engine: 350 w/carb no mods
Transmission: th 350 w/shift kit & 2800 stall
my car will turn over but will not idle at all unless I keep my foot on the gas. It wont rev over 1,000 rpm and I smell unburned gas when I stand by the hood. Do you think it is my fuel pressure regulator or the fuel pump? Which one should I check first? This is not the original motor but a 350. not sure exactly what it came fout of. It has centerbolt heads so I assume 1987-1995 if that helps. thanks for your help.
Old Dec 13, 2004 | 06:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would check the choke first.
It didn't have a fuel pressure regulator from the factory - if it has one, somebody added it. The only way it could be a fuel pump problem is if the carb is flooding, and if the carb is flooding, it might not be the fuel pump's fault.
Ghettobird52
Jul 5, 2024 11:18 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
Sherpajames
Aug 7, 2015 06:56 PM
