Modified SuperRam/TPI Fuel Rails for rear fuel lines?
Old Oct 19, 2004 | 07:17 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Has anyone modified their SuperRam/TPI fuel rails for fuel line fittings at the rear of the engine? I'm looking to put -6 AN fittings on the rails, and I was wondering how folks set this up. Anyone selling a set, even better! Pictures!
Old Oct 19, 2004 | 08:43 PM
JMatlock88's Avatar
Car: 1991 Formula
Well I just answered my own question with a search. :-)
If anyone knows what fittings are necessary, I would appreciate it!https://www.thirdgen.org/techbb2/showthread.php?s=&threadid=178248&highlight=rear+exit+fuel+rail
Attached Thumbnails Modified SuperRam/TPI Fuel Rails for rear fuel lines?-fuelrail1.jpg
Old Oct 20, 2004 | 08:22 PM
JMatlock88's Avatar
Car: 1991 Formula
Anyone know what fittings those are? bump
Old Oct 21, 2004 | 12:30 AM
JMatlock88's Avatar
Car: 1991 Formula
Okay, after hours of searching I have finally located SOMETHING of interest. I located some pictures of the fuel pressure regulator outlet tube fitting. It is an o-ring type fitting with no threads. Next to it (B) is a fitting that is I THINK made by Street and Performance. I havent been able to find the fitting in their catalog. Anyone know who sells this?
Attached Thumbnails Modified SuperRam/TPI Fuel Rails for rear fuel lines?-regulator23.jpg
Old Oct 21, 2004 | 12:34 AM
JMatlock88's Avatar
Car: 1991 Formula
The above fitting takes care of the rail outlet, IF someone can help me find it.
I am still unsure how to go about plugg the original inlet (circled). ...What thread is this?
Attached Thumbnails Modified SuperRam/TPI Fuel Rails for rear fuel lines?-fuelrail2circled.jpg
Old Oct 21, 2004 | 12:36 AM
JMatlock88's Avatar
Car: 1991 Formula
Lastly, the rails come plugged here from the factory. I need to know what thread/size this is (circled).
Attached Thumbnails Modified SuperRam/TPI Fuel Rails for rear fuel lines?-dcp_0003_1circled.jpg
Old Dec 12, 2004 | 04:32 PM
elcamin0_77us's Avatar
Car: 77 El Camino
Engine: 355 Converting to TPI
Transmission: Converting to 4L60/4L60E
Hey, I know this thread is around 2 months old. But, I've got some answers for you. Yes, Your right, they are S&P parts. If you download the S&P 2005 Catalog on page 46 you'll find them in Picture A listed as 6 & 6a. Their 2005 Cat is not that clear although their 2004 is. They're both AN6 fittings. I hope this helps, I too have been looking. This setup would help me out alot on my swap into a Camino.
Bill
Old Dec 12, 2004 | 05:08 PM
JMatlock88's Avatar
Car: 1991 Formula
Thanks, Bill. I have already finished modifying my rails and have plumbed my entire fuel system using -6 AN line. I had a fitting welded to my rail in the rear and tapped the regulator for an NPT--->6AN fitting. Hope you get yours figured out!
Old Dec 13, 2004 | 06:33 PM
Car: 77 El Camino
How did you plug the fuel line going into the fuel rail? I also thought about tapping the regulator, but since no one had mentioned it I figured there was a reason. What size NPT did you go with?
That would be a cheaper route.
Thanks Bill
92camaroJoe
Jul 29, 2023 07:57 PM
Andrew6.688
Dec 13, 2015 10:59 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
