what vacuum do you get with your cam
Old Dec 13, 2004 | 10:35 PM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
just wondering what actual vacuum to expect with a more aggressive cam. id appreciate knowing what anybody else has found and at what idle rpm too.
Old Dec 14, 2004 | 01:22 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Every engine will respond differently to cam changes..... dispacement, compression ratio, and cam choice all play a big role in how much vacuum the engine will make at idle.
See my signature for details of my engine..383 w/10.2:1 compression. My current setup has about 10in of vacuum at idle (800rpm) with comp hyd/roller (242/248 dur @.05, .540/.560 lift). My old cam was a bullit hyd/roller (225/230 dur. @.05, .525 lift). It made about 13-14in of vacuum at 750rpm. Hopefully that info helps.
Old Dec 14, 2004 | 05:46 PM
nsimmons's Avatar
15"s with a summit 1103, in sig
800rpm idle
Old Dec 14, 2004 | 06:37 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
17 in/hg. 3.4 liters, sucking through a soda straw. Wonder what would happen if I had a better intake manifold.....
Old Dec 14, 2004 | 08:34 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Mine pulls 15" at idle and I did install a vac can before taking down the road "just to be sure" this set-up I have now is teh best brakes the cars every had even when it was a stocker with 4 factory disc brakes.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
