A/C Problem ... Something I haven't heard of before
Old Jun 5, 2001 | 10:14 PM
88 GTA Notchback's Avatar
Here's the problem.....
- When I turn on my A/C the air is hot
- once I get moving ... it cools off
- about 30 seconds after I stop at a light.. it gets warm again
- when I get moving again ... it cools of...
WTF????
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT
88 Mustang GT
94? Impala (real close)
97 Dodge Neon
86 Corvette
2000 Prowler
And more Civic's then I can count. Why do they even bother?
Old Jun 5, 2001 | 10:20 PM
Guest
Guest
Posts: n/a
Its either low on refridgerant (sp?) or the cooling fans arent coming on with the AC on like they are supposed to. The fans are more likely.
Old Jun 5, 2001 | 10:25 PM
Vader's Avatar
88,
If the fan(s) are operating as they should, don't be surprised to find a loss of refrigerant. I had the same issues with my '86 about four years ago, and had to go an extra 10oz. of R12 to get the pressures adequate at such low compressor RPM (at idle) to get effective cooling.
If the fan(s) isn't operating shortly after the compressor is cycled on and you have adequate high side pressure, check the pressure switch and connections at the high side. It should close at about 175PSIG if my memory isn't totally gone.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 6, 2001 | 09:40 AM
MAXGTA2002's Avatar
If that don't check out, check your vacume for leaks or cracked vacume canister.
Old Jun 12, 2001 | 11:11 AM
Thanks Guys...
I think it's the refrigerant. My a/c has is now warm as can be.
Jacob
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT
88 Mustang GT
97 Dodge Neon
86 Corvette
2000 Prowler
BADNBLK
Nov 16, 2016 09:12 AM
R3500
Aug 24, 2015 09:05 AM
