Speedo stops? works? stops? and well...yea
Ok, here goes.
I get off of work last week, drive across town, look at the speedo and notice that its not working at all. So i get onto the interstate to head home and as soon as i throw it into 4th the speedo kicks back in gear and works fine for another week. Today gets here and it does it again. Except this time, while it wasn't working i hooked diacom up and noticed that the ECM could see see what speed i was going even though the speedo needle wasn't responding, which is basically all i care about(so the car will run correctly).
Any ideas to what is going on??
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Brendan
Car: 86' Z28
Engine: 355
have you had the guage cluster out lately? You may not have hooked the speedo cable up correctly.
Just a thought...
Eric
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Just a thought...
Eric
My 1986 Z28
beachrodder
Aug 7, 2015 04:27 PM
