Some Kind OF Problem
Old Dec 19, 2004 | 09:15 PM
5speedbird's Avatar
got a 88 firebird 2.8 5 speed
as im driving (in 2nd and 3rd) around 2500 3000 rpms the car bucks like driving at a low speed in a higher gear
Ive replaced the wires, cap n rotar, checked the plugs and they looked fine, and ive messed with the timing a lot.
ive got no clue what it could be any answers or help?
Old Dec 19, 2004 | 09:45 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Any engine codes? Is the 'Check Engine' light coming on? That could point to something.
Old Dec 19, 2004 | 09:47 PM
ljnowell's Avatar
Re: Some Kind OF Problem
Bad idea to mess with the timing, if it was right before, it will still be right. Timing wont move on its own. Have you checked the coil and module? Sounds very similar to something that happened to me on my 87 MPFI 2.8. Coil was bad, replaced it, and the coil went bad again. Module was shot, and took out two coils. I was just getting ready to do a 350 swap on it, so i just yanked it. Its not hard at all to fix though, and a search of these boards will yield a thread or two detailing it.
jhawkeye
May 25, 2022 06:33 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
db057
Aug 22, 2015 08:17 PM
novaderrik
Aug 10, 2015 12:44 PM
Newguy91rs
Aug 7, 2015 09:51 PM
