Cruise Won't work...
Old Dec 20, 2004 | 07:32 PM
LD1985's Avatar
Car: '91 RS, 1994 Honda Accord LX
Engine: 3.1
Transmission: Automatic
My cruise hasn't worked as long as I have owned my Camaro....I have replaced almost all of the vaccum lines in the car and under the hood......Even tried replacing the control arm on the steering column. What else could be causing this malfunction?
Old Dec 22, 2004 | 07:59 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
I was working on my cruise control yesterday. It also hasn't ever worked.
All vacuum lines are good, and I replaced the vacuum tank prior to this because it had a hole in it.
The brake switch and the vacuum release valve at the pedal are good.
It is getting 12 volts everywhere it is supposed too and the switch on the turn stalk is ok.
Speed sensor and buffer are good.
The only things left that could be bad are the servo and the module.
Old Dec 22, 2004 | 11:23 AM
Morley's Avatar
There is one other thing to look at. there are 2 floating metal "plugs" in the servo that over time get covered with crud and won't allow the cruise to engage or will cause it to surge (first symptoms).
Old Dec 22, 2004 | 02:15 PM
bru333's Avatar
Car: 1987 Camaro SC
My cable was out of adjustment! I moved it 2 holes on the servo, making the cable tighter at the throttle, and now the cruise works. I love it when fixes are that simple and cheap.
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Sep 16, 2015 09:15 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
