Car won't start. Checked just about everything. Could it be the VATS??
Old Jun 11, 2001 | 07:43 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
Today when I was leaving work, I went to start the car and it wouldn't crank. I tried about four times and on the last one, it started right up. When I got home, it wouldn't start again and hasn't since. I've checked just about everything under the hood and I've started to get my hands dirty with that mess of wire harnesses under the dash. At first I thought it was my clutch safety switch but that wasn't it. I've checked a buch of the other wires and all the fuses to no avail. I'm guessing it has to do with the VATS. After dinner I'm gonna go back out and try to find those wires and check them. Any tips on what to look for? I'm really in a jam here.
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Jun 11, 2001 | 07:50 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
yea it could be the vats, but if you did have trouble with the vats you wouldnt be able to start the car at least 10 min after the first try. vats disables the ignition system at least 10 min after a illegal entry. If you just kept trying to crank and all the sudden it started, then I would look to your ignition switch under the steering column, or the starter relay mounted on your starter.
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out....
www.formula350.com
or click below to email me
webmaster@formula350.com
Old Jun 11, 2001 | 08:00 PM
OK thanks. I had thought of the ignition switch being bad but that went bad and was replaced about a year ago. I guess it could've gone bad again though. I'll check it to make sure.
Old Jun 11, 2001 | 08:36 PM
Alright I was able to start the car by rolling it down an incline and then putting it in gear and cranking it. This means my ignition switch is fine doesn't it? What else would it be besides the VATS? How do I check and fix or bypass the VATS?
Old Jun 12, 2001 | 12:58 AM
ArnoldBraker's Avatar
Like formula90 said, check the starter relay and related wiring. ~Arnold
Old Jun 12, 2001 | 12:48 PM
I found and fixed the problem. One of the previous owners had ghetto-rigged a wire coming from the ignition switch by twisting the wires and putting electrical tape around it. No solder or anything. Makes me wonder what else has been messed with on the car. Anyways I just soldered the wire together and shrink wrapped it and the car starts no problem now. Thanks for the suggestions though.
Old Jun 13, 2001 | 04:59 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
thanks for the feedback. It had nothing to do with your vats and everything to do with your ignition switch. the switch itself was good, just wired crappy. explains how you were able to push start it....cool....at least it was simple...
www.formula350.com
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 9, 2015 05:27 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
