heads hp
Old Dec 22, 2004 | 03:15 PM
aaf815's Avatar
Car: 1986 Z28
Engine: LG4 V8
heads hp
how much HP gain will a lg4 get with heads.
Old Dec 22, 2004 | 03:34 PM
PontiacRacing's Avatar
Car: 1987 Pontiac Trans Am GTA, 1992 Chevrolet Camaro RS
Engine: Custom 350, 3.1 V6
Transmission: 700R4, 700R4
This is the wrong board to ask that. You'd probably have more luck in one of the engine boards.
Old Dec 22, 2004 | 04:19 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Thats a pretty broad question... can you be a little more specific?
Old Dec 22, 2004 | 04:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Just heads? Not much.
Improvement in the heads is needed in order to take advantage of other improvements. The order of importance goes something like this: 1) Air cleaner; 2) exhaust; 3) cam; 4) heads; 5) intake manifold.
You can justify #1-3 without 4 or 5. However, 4 or 5 without #'s 1-3 is a waste of time/money.
You don't need to replace the heads, although that's what I did. Basic porting with 1.94" instead of 1.84" intake valves, better valve springs, and screw-in or pinned rocker studs will make a vast improvement.
Old Dec 22, 2004 | 06:26 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The heads you have now are not your problem. The exhaust, intake, and cam are what make your engine a non performer. The LG4 actually has desireable heads for a 305 and can be prepped to make more power than your 305 will ever make. If you keep your 305, keep the heads. Replace the cam, intake and exhaust to make power. The heads on an LG4 are basically at the end of the "weak link" list of stock parts.
Old Dec 22, 2004 | 08:00 PM
aaf815's Avatar
Car: 1986 Z28
Engine: LG4 V8
perfomance heads
Old Dec 22, 2004 | 08:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Nothing
Unless you do a whole bunch of other things first
You might even slow your car down
Listen to what they're saying, it's true
Old Dec 22, 2004 | 08:15 PM
ljnowell's Avatar
Originally posted by aaf815
perfomance heads
The heads that are on the 305 will be performance heads enough for a 305. Have them machines for 1.94 intake valves, better springs for a good cam, and screw in studs. That or go cheap and pin your studs.
Old Dec 22, 2004 | 09:13 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Just go to a yard and get some 305 castings for your year, have them done up, port and polish them, make them nice. Do what LJ said to do about the valves and what not. Put them on when you are ready. That's essentially what I did.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
