BROKEN DIPSTICK TUBE- can I lose oil?
Old Dec 23, 2004 | 02:42 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
the dipstick tube snapped off at the header- and lately my oil pressure has been up and down (from 30-60psi erradically) and I have put 3 qts into it in the past 2 weeks... what the hell.
Old Dec 23, 2004 | 06:30 AM
ede's Avatar
ede
oil pressure and the amount of oil in the engine are not directly related. sure you can lose oil if there's an opening for it to leak out and if enough leaks out you can lose oil pressure
Old Dec 23, 2004 | 08:30 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
well my oil pressure has been bouncing around a lot lately- any idea at all what it could be? do oil pumps die? could my filter be so clogged that it's restricting that much? I mean it's been almost 3k but still...
Old Dec 23, 2004 | 08:55 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Is it a Fram?
Old Dec 23, 2004 | 08:56 PM
ede's Avatar
ede
WAG you need a new sender
Old Dec 23, 2004 | 08:58 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Ok, I'll be serious and sober for a sec, yes it could happen because of the filter, if there were a problem with the bypass valve in it.
Hotrodboba400
Dec 10, 2019 07:07 PM
skeltor
Feb 2, 2016 10:37 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
