Real Tech Question, Ive Confused myself.
Old Jun 11, 2001 | 02:19 AM
Bort62's Avatar
Allright guys, This Is a bit of a follow up On a post I made a while back, Ive proceeded to get myself A little On the confused Side.
There are Two 6 and 3/4 Harmonic balancers. One with the Timing Mark strait Up Above the Keyway, and one with it Offset approximately 1.75" From the Keyway.
Soooo, Since The Lg4 in 85 came Stock with the Offset Style, and I replaced it with a Strait Up Style, How Much Do I have to compensate On My Timing To Make the other Mark read true.
By My Calculations, It should Be about 15*. Now, is this Advanced Or retarded ( Or am I just retarded ? )
Using a Dial back Timing light, I can get Up to 60* advance. However, I cannot Dial In retard. ( 1-800-Retard )
If someone Could answer these Questions Definitavely For me, It would be Nice, I am trying to dial in My timing Curve very specifically and Obviously, This is a bit of a obstacle.
Thanks Alot, Hitting the 1/4 on saturday and need to establish a baseline before i Start making the little adjustments
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 15.26 @ 87.0
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 11, 2001 | 04:04 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Get the timing pointer to match and you won't have to compensate for it at all.
Old Jun 11, 2001 | 04:21 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
sounds like its time for a degree wheel and tape...
zroc
Old Jun 11, 2001 | 09:45 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'll probably screw this up, but what the heck....
The circ. of a circle is 2*pi*R
so 6.18*3.375=20.86
the ratio of the offseet of the mark would be 1.75/20.86= 8.39%
8.39% of 360 degrees is 30.2 degrees.
Now I'm not a math major, nor do I play one on TV, so please double check my work
Old Jun 11, 2001 | 10:32 AM
SUPER-SPORT-CHEVY's Avatar
I've wondered this my self except my senario was the reverse of yours. I ended up changing the ballancer, but in your case I recomed making life easy by purchasing a 3.99$ timing marker and slaping it on. There is a way to time it with vacume but im not to familar with how its done.
SSC
Old Jun 11, 2001 | 12:08 PM
Bort62's Avatar
Question Is, Will I be able to see My new Timing Mark, With a Long Styl Waterpump ?
Old Jun 11, 2001 | 03:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
This is a carbed car?
Who cares what some mark says, this week, until the inertia ring runs around on the little blob of spooge to somewhere else? Just set it to where the car runs the best.
ICON Motorsports
Old Jun 11, 2001 | 04:10 PM
Bort62's Avatar
Well I would Do that RB, but im trying to Get as Much Initial timing as I can w/o Ping under load, then dial in my adjustable Vac advance to Put in as much as it can w/o ping under no load, Yeilding the best milage and best performance possible
Old Jun 11, 2001 | 04:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
So where does a mark figure into all that?
Sounds to me like you get into the car, hit the freeway, floor it through the gears; if it doesn't ping, stop, crank the dist CCW; repeat until it does ping; stop, back it off a little; add some high-vaccum advance; go up a hill at cruise in high gear; see if it pings; if it doesn't, stop, add some more; repeat until it pings; stop, back it off a little. Done. No mark required. I don't see where a mark speeds up or otherwise improves that process any.
I guess I'm just too lazy to fool around with some kind of a mark that doesn't contain any meaningful data. That is to say, if the mark was within one degree of dead-on-*****, would you have to experiment any less to get optimum results with your compression, heads, cam, carb, gasoline, altitude, density, ambient temp, coolant temp, gears, driver preference, and all the other things that determine optimum timing? Would it make any difference if the mark even existed?
ICON Motorsports
[This message has been edited by RB83L69 (edited June 11, 2001).]
Old Jun 11, 2001 | 05:09 PM
Brent's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
I think the timing mark has merit. I want some sort of reference so after I've spent alot of time finding the timing the engine wants, I can set the dissy back to that spot incase I have to tear down. The numbers aren't really important, just a reference. TDC on the balancer can be checked easily with a piston stop. Marking the center hub will tell you when the outer ring has slipped.
Old Jun 11, 2001 | 05:18 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
RB, since moving to Ca., have you had to have your car smogged yet? If so, you'll find that many, many places will not pass you if your timing is more than +/- 2*'s from factory spec's, I'm not sure if this is actually a law, but worth looking into.
Old Jun 11, 2001 | 10:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
<font face="Verdana, Arial" size="2">Originally posted by Bort62:
</font>
Lean waaaaay out over the car and aim the light straight down the front of the block behind the pump.
Old Jun 11, 2001 | 11:28 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
<font face="Verdana, Arial" size="2">Originally posted by 8Mike9:
</font>
The circumference of a circle is diameter*pi. That's all. Nothing more. So the way you had it would be 2*r*pi. But 2*r would be the diam.
The Area of a cirle is pi*radius/squared.
Edit: Make that radius/squared*Pi. You gotta do the square part first, then multiply by Pi. Sorry
[This message has been edited by AJ_92RS (edited June 11, 2001).]
Old Jun 11, 2001 | 11:31 PM
AJ_92RS's Avatar
</font>
You can also use it to set/check your timing curve. That is just as important, if not more, than your total timing.
Old Jun 11, 2001 | 11:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You sure about that AJ? I gotta go do a web search...it has been 22 years since highschool, but didn't think I was getting that old to forget
Back in a few....
Try this link:
http://www.geom.umn.edu/docs/reference/CRC-formulas/node25.html#SECTION016000000000 00000000
It also shows the circumference of a circle as 2*pi *R
Oh, and no, I didn't have it as 2*R *pi
[This message has been edited by 8Mike9 (edited June 11, 2001).]
Old Jun 12, 2001 | 01:28 AM
Bort62's Avatar
lol Okay guys
Communutive property If 2*r=D
A*B = B*A, A*B*C = C*B*A
Then 2*pi*r = 2*r*pi = d*pi
mix and Match how you like, With multiplication and Addition, It dosent matter
( subtraction and division are a differnt story! )
Rb, I am tryin to establish fairly accurately what My timing is across the rpm Band, by taking measurements every 250 RPM from 500 to 3000, and graphing it vrs each other With Differnt settings Of Initial Timing, Vaccum advance, and Advance weights and springs...
THUSLY I will get an accurate portrayal of exactly where My advance is at at what RPM depenant on Load, and I will be able to see what Im working with, and maximize it for efficency.
I want To go faster For free, Tuning people Tuning
On a Carbed car, You have control Over Mixture, Temperature, Timing, and Plug Gap, These things Will Make or break The Engine, regardless of the $$$ In parts it Is made up Of.
Reader's ride -&gt; My Ride
Old Jun 12, 2001 | 06:53 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Simple, every inch on a 6.75" balancer is equal to 17 degrees.
Well, actually 16.97 but 17 will work...
Old Jun 12, 2001 | 09:51 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
lol Okay guys
</font>
DOH!!
Light bulbs are beginning to come on.
But, hey, I did get the circumference right, huh?
Old Jun 12, 2001 | 08:18 PM
JoelOl75's Avatar
Can you step up to the 8" balancer in the third gens without any probs? I heard the models with factory engine oil coolers the hb hits the coolant line, but how about w/o the engine cooler. Any other probs (pulleys bolt right on?)
Old Jun 13, 2001 | 10:36 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Hey bort, grumpy has apost on the PROM board selling a complete TPI setup w/ a SD ECM (you need a harness and fuel pump, thats it) for $150.
join the dark side....then you can see your timing for every condition...woo hoo
Old Jun 13, 2001 | 02:21 PM
Bort62's Avatar
No **** Ed ?
Hell with this stickdadikinda *** BULL****!
I can Almost Afford that, lol
Old Jun 13, 2001 | 02:28 PM
Ed Maher's Avatar
Car: 04 GTO
Yeah, no sh it...it's titled Early TPI...better get an email in soon cuz if too many people read this, somebody will take it.
Of course there's still the issue of that cam w/ TPI, but hell, maybe you could sell your top end and cam and recoup the cost of the swap and something more TPI friendly.
Old Jun 13, 2001 | 02:33 PM
Bort62's Avatar
You are a *** ed
He wants 300 ! Got me all excited an ****...
As far as that being to Much Cam, I could work around it, I mean after all I have you To write me chips, right ?
Old Jun 13, 2001 | 02:47 PM
Ed Maher's Avatar
Car: 04 GTO
i *love* the chip i have in now. I drove around a little for lunch and didn't get any pinging whatsoever. And my car loves all this low end timing i'm giving it.
And 150, 300, same difference. I'm lucky to remember my name these days
Old Jun 13, 2001 | 02:53 PM
Bort62's Avatar
Just rememeber your lean!
Now, be useful, and Find me a list of Secondary metering rods frmo richest to leanest, So I can Fufill this pipe Dream I have of going fast with a Qjet!
Old Jun 13, 2001 | 03:23 PM
AJ_92RS's Avatar
Did anyone on this board take geometery in school? Go to http://www.mathgoodies.com/lessons/v...umference.html
Here's a shortened Ex.
The radius of a circle is 2 in. What is its circumference? (Use Pi = 3.14)
Solution: C = Pi · D
C = 3.14 · (4 in)
C = 12.56 in
As far as area here's and Ex.
A = Pi · R · R or
A = Pi · R squared
The radius of a circle is 3 in. What is its area? (Use Pi = 3.14)
Solution: A = Pi · R · R
A = 3.14 ·(3 in.) ·(3 in.)
A = 3.14 · (9 square in.)
A = 28.26 square in.
BTW, it does matter what order that's done in. I just wanted to make sure you knew not to multiply pi*radius, then square it, to find the area. You have to square the radius first. I just screwed up the way I wrote it the first time.
As far as circumference, it don't matter which way it's done, because you aren't squaring anything. I was just showing the simplified formula as dia.*pi, instead of R*2*pi, that's all. Even though I'm square.
[This message has been edited by AJ_92RS (edited June 13, 2001).]
Old Jun 13, 2001 | 03:25 PM
Bort62's Avatar
<--- Calculus III next Semester
But Its Still Not adding up
Old Jun 13, 2001 | 04:12 PM
Ed Maher's Avatar
Car: 04 GTO
dude, just get some timing tape and be done with it for christ sakes. Or bust out a tape measure and do it yourself. Timing tape can't be more than a few bucks...
Old Jun 13, 2001 | 09:08 PM
JoelOl75's Avatar
Yeah, all this balancer stuff and marks in diff spots is freakin me out also. I'm just going to fab up a pointer to point anywhere on the balancer. Use a stop to find TDC, stick timing tape on it and be done with it...
Old Jun 13, 2001 | 11:09 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
</font>
Oh, now I get it. You're **** retentive! Now I understand!
j/k
I think that what Rb was trying to say is that even if you are trying to map out your timing curve and fine tune the thing for optimum performance, the shape of the curve will be the same regardless of the actual starting point of the curve, so the actual numbers on the balancer at idle are sort of immaterial. Whether the base timing is zero or ten doesn't make much difference as far as your tuning goes. The magnitude of the changes you make, and the rpms at which you make them are important, but if you add four degrees of advance at 2750, say, it still becomes four more degrees of advance at that point regardless of what your base timing was.
I would just suggest picking a spot and calling that your zero point and working from there. YOu have better things to do than trying to futz with the balancer.
BTW: Math minor along with my aerospace engineering degree. Three years of college math. Toss me some challenging formulas for a change, guys!
Cleotiz
Jan 6, 2018 08:56 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
