Roller rockers from Summit...
Old Dec 27, 2004 | 12:50 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Ok, so I have the LG4 engine, which is like "Lift? what's that?" so I am looking at 1.6 rockers. I found the following two at Summmit, and I was just wondering if they look half decent to you experts, and if they will work with my 416 heads without machining or anything.
http://store.summitracing.com/defaul...4924497+302284
Old Dec 27, 2004 | 09:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Both links go to the same part.
Regardless, I wouldn't bother. For that $159, you could get a real cam. You will most likely need at least new valve springs, and depending upon the final at-valve lift, do some guide shortening.
Old Dec 27, 2004 | 09:50 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
agree 100% you can get twice the power gain for half the money with a new cam swap, including new valve springs.
Don't be a *****... pull the timing cover and intake manifold and swap the camshaft.
real men swap cams not rockers
Old Dec 27, 2004 | 09:53 PM
70BuickSleeper's Avatar
Car: 84 Z28
Engine: 305 HO
Thats just funny as hell, i think im going to **** my pants
Old Dec 27, 2004 | 10:45 PM
305q_ta86's Avatar
Transmission: 5 spd
Oops.. the other link was supposed to go to a crappier $100 version.
Anyhow, I do not intend to keep the 305 for a really long time, so I was thinking I could just do the rockers to keep me happy for a while.
The thing is, I dont have access to a shop too often, so a cam would be a buttload harder for me to do. If I remove the radiator, I can swap the cam with the engine still in the car though, right?
Well I'll do some research and find out what cam I want and then ask some questions like whether or not I will have to change this or that part and all that.
How long would a cam take for a first timer with the help of his shop teacher?
Old Dec 27, 2004 | 10:48 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Cam swap in sig. It can be done in an afternoon.
Old Dec 27, 2004 | 11:00 PM
Parrydise7's Avatar
At what kind of engine mileage do you forget about a cam swap? Or, do you go by a compression check and let that be your guide as to whether you swap a cam or just go for a complete engine rebuild?
Thanks!
Old Dec 27, 2004 | 11:10 PM
305q_ta86's Avatar
Transmission: 5 spd
Thanks!
Oh yeah... Good question. Mine has 130,xxx miles on it. that's why I was thinking just rockers for now, because I dont have much money and I just want to have some funwith this engine before I get a 350 next summer...or the one after that...
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
