Car smokes at idle.....
Old Jun 14, 2001 | 01:07 AM
idrag2's Avatar
Topic says it all.....it don't smoke going down the road but let it idle for 30 to 40 sec's and hit the gas and a BIG puff of blue smoke comes out. I was told this is a sign of the valve seals going out. If so what type of seals should I use, Umbrella, O-Ring
or Postive Type seals. Give me your Ideas.
Thanks Guys,
I Drag 2
Old Jun 14, 2001 | 01:48 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Doesn't sound like valve seals to me.... valve seals usually show up with a puff of blue smoke on startup due to oil leaking past the worn seals down the valve stems and into the CC when the car has been sitting for a while, then burning off when the car is started.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
http://www.geocities.com/transam85tpi/
Old Jun 14, 2001 | 11:14 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Sounds like piston rings to me.
Old Jun 14, 2001 | 12:34 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
ring wear..
i've got one word for ya.. "REBUILD!"
Webmaster: www.IROC-Z.org
bryan623
Mar 22, 2021 06:43 PM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
