cars runnin like a$$
Old Dec 27, 2004 | 04:21 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
last night my car starting runnin bad mainly in the lower rpms. it would sputter, almost feeling like someone bouncing on the clutch. i know its not my clutch cuzz its new, so i figured it was my fuel filter which has never been replaced, so i replaced it, cut the old filter open, it looked horrible. but the problem continued. then my service light came on and it flashed code 42. i took my ignition control module to be tested at oreilys. after about 10 tests, each time it showed it was faulty in the low rpms. which is where my problem was most apparent at. so i got a new one, put it in...and my problem still continues. code 42 shows it would be ether fault at electronic spark timing circuit or fault at direct ignition system or fault at fuel cutoff relay circuit. could my problem be fuel system related? is there any way to check fuel pressure on tbi? thanks in advance
Old Dec 27, 2004 | 04:27 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Reset the computer.
You used the white heat sink compound, not the clear dielectric grease on the back of the module didn't you?
Old Dec 27, 2004 | 04:31 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
there wasnt anything supplied with it, should there have been?
Old Dec 27, 2004 | 04:56 PM
ThommyDee's86Z's Avatar
Car: 86 Z28 w/ T Tops
Engine: 305 SB w/ Performer intake 3701
Transmission: 700 R4
Axle/Gears: stock
You got to coat it good or it will overheat and short out. Sometimes they put a little tube in the box, usually they do not.
Remove the black wire from the battery for 10 min to reset the codes.
Old Dec 27, 2004 | 05:01 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
well i didn't put any on it, and i drove around the block a couple times...any chance i could have overheated it?
Old Dec 27, 2004 | 05:07 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
:shrug: Bring it back and have them test it. I usually have them test the ones I buy as well. I have found ones that did not pass right off the shelf.
If they come with the clear dielectric grease, or if they come with nothing, ask for Wells part no.SL203. Should be two tubes of the stuff.
Old Dec 27, 2004 | 06:18 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
i just reset the comp, put on the grease...still runs horrible
Old Dec 27, 2004 | 07:00 PM
Axle/Gears: stock
Did it throw the code 42 again?
It could have been shot already as Ruby said.
Old Dec 27, 2004 | 07:07 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
well i went and had it tested, after i had drove it around earlier, and it passed each of the 5 times so...no code yet.
Old Dec 27, 2004 | 07:13 PM
Axle/Gears: stock
Did you say it was running bad before it threw the code?
Old Dec 27, 2004 | 07:20 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
what do you mean? as in before the light came on? yah
Old Dec 27, 2004 | 08:06 PM
Chilo's Avatar
Car: 91 Z28
Engine: 355 TPI
Transmission: Streetfighter 700r4
My brother's 91 RS TBI had the same problem that the only way it would get power was to down shift it making sure the rpm's were high enough. Bought a new fuel pump and had a mechanic replace it. Before he actually installed it, he called me to let me know that that wasn't the problem. Problem was that one of the injectors was cloged and the other one was barely flowing. Went ahead and replaced both injectors and fuel pump as well. Solved that problem.
Old Dec 27, 2004 | 08:36 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
well makes sense, but it doesn't sound like that would have anything to do with code 42. the only related fuel system componant to code 42 is the fuel cutoff relay ciruit, which, correct me if im wrong, should only be used in the event of an accident or turning your car off. but hey, if the circuit is malfunctioning, would it effect fuel delivery?
Old Dec 27, 2004 | 10:00 PM
Chilo's Avatar
Car: 91 Z28
Engine: 355 TPI
Wouldn't know much about the whole code thing, but didn't you mention that you had checked it 5 more times and no more codes. So are you getting anymore codes? Well my brother's car was getting a code but I was just too lazy to check it out. Took it to one shop and a code came up. They said it was running lean. They wanted $600 for a complete tune-up plus O2 sensor. I ended up doing it myself for 1/4 of the price and nothing. Good thing I did pay the shop to do it. Always knew it had to be a fuel problem since the begining, but couldn't convince my brother. The car basically idel smooth, but when crusing at a low rpm I would give it a little gas and the car would feel like it would misfire really bad. Would always have to downshift. Just telling you from experience. May not be the the problem but just wouldn't want you to go out pay $600 for a tune-up that wouldn't have even solved anything.
Old Dec 27, 2004 | 10:10 PM
Axle/Gears: stock
Maybe.... The 2 are not related (The code and running bad)
Maybe a cloged injector is causing the stumble.
Maybe you fixed the code with the module.
:shrug:
Old Dec 28, 2004 | 01:45 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
now the idles bouncing up and down
Old Dec 28, 2004 | 01:52 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
and now its throwin 42 agian
Old Jun 16, 2009 | 03:33 PM
ogg__666's Avatar
Car: 1988 iroc-z28
Engine: 305 tbi
Transmission: new 700r4
Axle/Gears: um 2.77 i think
Re: cars runnin like a$$
hey can anyone help me out im goin crazy with my 88 iroc when i got it it had trany probs and 2 weeks a go it died on my on the side of the road so i cleaned my ignion module and it died on me befor i got home so i went and got a new module and now my trany aint got no probs but if my car isnt moveing it bogs down to 500 rpm and either kicks its self up to 1100rpm or it stalls on me WTF ???
Old Jun 16, 2009 | 03:38 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
why don't you create a new thread instead of bringing this almost 5 year old thread up?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
