Trunk mounted battery
Old Jun 15, 2001 | 12:03 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
For you guys that are running a trunk mounted battery, how did you route the battery cable from the rear to the front? I would prefer not to drill holes (except for the obvious one in the trunk floor) for straps to secure the cable.
Old Jun 15, 2001 | 12:17 PM
Brian K's Avatar
I ran t along the fram rail and lip under the car and it came in under the rear seats. Take the cshio off and there is a lot of space. It then ran along the indie plastic totaly unseen. My kit came with a plug to prevent water from coming in.. No problems 2 year later..
Old Jun 15, 2001 | 03:39 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Did you all use a sealed battery or sealed battery box?
Old Jun 15, 2001 | 03:55 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
moroso sealed bb. I drilled holes and ran mine on the outside. Used real small upolstery self tapping screws and clamps with rubber liners.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
SG91camaro
Sep 5, 2015 10:27 PM
andy74
Sep 3, 2015 08:41 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
