help figuring what this block is
Old Dec 31, 2004 | 07:55 PM
Kaukasion's Avatar
Car: 84 z28
Engine: older 350, details unknown
Transmission: th350
Axle/Gears: factory limited slip
3970010 302 69 4 Camaro Z28
3970010 350 69-80 2 or 4
ive came up with that in my search
its in a 84 z28
how can i tell which one it is for sure?
please help its urgent
Old Dec 31, 2004 | 08:01 PM
nsimmons's Avatar
you can check the pad stamped by the water pump for specific information on what vehicle it came in, but with out the crank its just a 4 inch bore block, it could be a 302 (i doubt) a 327 or a 350(most likely)
Old Dec 31, 2004 | 08:08 PM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
i cant find it ????
water pump is in a weird spot
where exactly would it be
Old Dec 31, 2004 | 08:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a 350 in all likelihood. All that number means is that it's a 4" large-journal block.
It doesn't matter what it originally came in; it's an extremely common 350 block from the 70s.
It's a 350, or at least should be. Nothing more, nothing less.
Old Dec 31, 2004 | 08:36 PM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
ok this person was trying to claim its some h.o. 350
what be a normal hp/tq rating for this motor it looks dead stock just painted and dressed up with a set of cheap headers
Old Dec 31, 2004 | 08:46 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
it would vary alot i would think the early early 70's block with 300+hp or the late 70s blocks with under 150hp
Old Dec 31, 2004 | 08:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No telling.
It's 30 years old, more or less. Who knows what's left of how it came. It probably doesn't have the original pistons, heads, cam, carb, or anything else that determines how much power it makes.
It's a 350. If you want to know anything else, you're going to have to get piston numbers, head casting numbers, cam specs, etc.
Or, take it to the dyno; since "predicting" power output even from a complete list of parts is notoriously difficult to do accurately. It makes however much power it makes: no more, no less.
Old Dec 31, 2004 | 08:54 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
It's a 350 High Nickel (sp) block., .010 on the end indicates it is.
The block really doesn't have a horsepower rating.
The heads/intake/cam installed set the power rating.
There is a pad on the block just in front of the passenger side head that has some numbers on it that tells exactly what vehicle it was installed in.
It's HARD to see and if the block has ever been decked the number was removed during the decking process.
Old Dec 31, 2004 | 09:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
010 is the last 3 digits of the casting number 3970010. It has nothing directly to do with nickel content. Although, many blocks with that casting number, since they were in trucks alot of the time, did get the better alloys.
None of which has anything to do with how much power it puts out.
If it had come in a 2-barrel application, truck or otherwise, it would have put out around 165 HP new; if it was a 4-barrel, maybe 180 HP.
Old Dec 31, 2004 | 09:18 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
If it's an 010 block it could also bea 4bolt main. I've never seen a 4 bolt that wasn't a "010" block, BUT, I have seen some "010" blocks that weren't 4 bolt main. Large journal that is.
Old Dec 31, 2004 | 10:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have built countless 350s out of 3970010 blocks. About 25% of them, give or take, had 4-bolt caps.
The casting number does not contain information about which main caps were installed.
All 3970010 blocks are large-journal. The casting number does contain that information.
You gotta take it apart and look if you want to know which caps are on it.
Lots of blocks with factory-installed 4-bolt main caps on the center 3 journals are not the 3970010 casting. There are numerous other ones (the later roller ones for instance) that have other casting numbers.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
andy74
Sep 3, 2015 08:41 AM
