My A/C compressor won't cycle!
Old Jun 15, 2001 | 03:42 PM
Synergy's Avatar
Hey everyone. I just had my A/C system serviced and a new compressor, orrifice tube and dryer were put in and everything converted to R134a. The A/C blows cold and works good, but the compressor doesn't cycle. It's on ALL the time. Is that normal ? The only thing that I did was removed the connector that goes in the high pressure line (the one that tells the 2nd fan to turn on) and shorted it to make it thik the AC is on and have the 2nd fan on all the time. Does that have anything to do with the rest of the AC system ?
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
Old Jun 15, 2001 | 03:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What makes it cycle is the pressure in the low side falling below some minimum value. The reason it is set up that way is to keep it from freezing when it's low of Freon and it's not real hot ouside.
So, if it's full of Freon and it's hot out, the pressure will never go low enough to make it cycle.
ICON Motorsports
Old Jun 15, 2001 | 10:20 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
The R-134A makes it worse since it runs warmer. It will probably cycle when the outside temperature is less than 60 degrees.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
junior419
Apr 7, 2025 11:35 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
Ironhead38
Sep 7, 2015 02:26 PM
