Do I need a catalytic converter for emissions?
Car: 1981 monte carlo/sold 1984 z28
Engine: 350 w/carb no mods
Transmission: th 350 w/shift kit & 2800 stall
I wanna try to pass emissions but I sont have any cats on my exhaust. If I fail I dont want them to look under my car and find out I dont have any cats. I was looking at this: http://cgi.ebay.com/ebaymotors/ws/eB...me=rvi%3A1%3A3 I only need to take my emissions test this one last time because my car is only two years away from being exempt from testing. Anyone familiar with this brand? Or can help me find a good cheap one?
Car: '86 Berlinetta
I've never seen those before, but if you have a V8, and a full catback exhaust, then that 2.5" cat will hender performance.
You might as well get a Catco Highflow catalytic converter for about 40 dollars more (off eBay) and never have to worry about it again (the high flow cats dont hinder performance like older catalytic converters do)
I just need a "throw away " cat just so pass the test and take it back off afterwards. I know catco seems to make a pretty good cat its just that I wont use it ever again after this week.
Originally posted by seanjuan
I forgot I need two of 'em cuz I got true duals.
I forgot I need two of 'em cuz I got true duals. Post pics of your exhaust routing and we'll go from there. Also, do you have an AIR pump?
Transmission: 4L80E/4L80E
3" is only $1 more. Most cats appear to be made by the same source, each company puts their own name on them. So, "Eastern" is probably really "Walker", or Catco, or they all get them from the same sweatshop.
However, I suspect the "true duals" is possible because of
"Car: 1981 monte carlo
Engine: 350 stock carb"
In general, you may not "need" a cat to pass emissions. In general, though, it will most likely help you pass the sniffer. In general, a cat is required to pass visual inspection.
In general, by board rules we have to limit specific discussions to 3rd gen specific vehicles. So, although "in general" this topic might apply, specifically it does not meet board rules.
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I run that brand cat from that particular seller actually. I've got a 3" and it's pretty good.
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
I have a question about the AIR system, why is it illegal to remove it?
And really, if you did remove it and put on new cats that did not need the AIR system then how could anyone notice?
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Re: Do I need a catalytic converter for emissions?
i live in iowa and have an 89 GTA and im thinking about taking the smog of gettin catback exaust headers with O2 and i was wondering if i should buy high flow cat or just delete the cat wich one would be best thanks
car is stock except gutted maf and airbox thanks to this site
Hotrodboba400
Dec 10, 2019 07:07 PM
