Question
Old Jan 3, 2005 | 01:12 AM
Hal3246's Avatar
Car: 1986 P. Firebird T/A
Engine: Stock v8 305 TPI
Axle/Gears: N/A
Question
I just bought a 1991 Pontiac Firebird Formula, so the kid says, with a 305, I put the vin number in the vin decoder and the info is different from the tech data on the side menu on the main page. Ok so is it a LO3 or the LB9? I don't have pics right now but I'll get some up, I have some outside pics if you can tell me anything by looking at it.. but I know it's either just nothing or something small. the pictures can be found on www.photobucket.com under album sin3246
Old Jan 3, 2005 | 06:53 AM
mojo_jojoe4's Avatar
Car: 1991 Firebird Vert
Engine: 383 L98/LT-1
305 TBI, better have got a good deal on the car.
Old Jan 6, 2005 | 05:27 PM
Hal3246's Avatar
Axle/Gears: N/A
Was 1100 why, is it that bad?
Old Jan 6, 2005 | 05:29 PM
Hal3246's Avatar
Axle/Gears: N/A
Oops my bad, I have 2 firebird, the 1991 formula can be found here http://photobucket.com/albums/v120/s.../My%20Dragons/ this is the one I'm asking about, nto the one with the red fender, the car is under my album (sin3246 -> my dragons)
Old Jan 8, 2005 | 04:58 PM
Hal3246's Avatar
Axle/Gears: N/A
^bump
Old Jan 8, 2005 | 07:00 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Just look at the engine, does it look like a carburetor or does it look a nice, with a big plenum and 8 tubes. Its really easy to spot the difference. If it looks like a carburetor and has a round aircleaner sitting on top, then it is TBI, yuck.
Old Jan 8, 2005 | 07:07 PM
Phantom Champ's Avatar
Car: 91 Formula
That isn't a Formula. The ground effects and front end look like a base model. It looks like a Trans Am hood was put on it. $1100 still isn't that bad of a price.
Old Jan 9, 2005 | 12:42 AM
Hal3246's Avatar
Axle/Gears: N/A
Thanks guys, it has a carb, 4bl... yuck? what is bad and/or good about a carbed enginge? Would it be better to swap it out for a TPI and change the computer or would that be too much... plus how much would that cost? (estimate) Hmm, another question, would GM/Pontiac put a trans am/formula gauge cluster panel for the base model, instead of the Speed/Fuel guage and dummy lites like I have on my 1987. Hmm, maybe that is the problem, my speedo doesn't work right, every other gauge works but the speedo doesn't work right, I saw it bounce a couple of times... but that was it, I know the miliage gauge work within the speedo gauge.. but the needle just doesn't budge.
Old Jan 11, 2005 | 03:57 PM
Hal3246's Avatar
Axle/Gears: N/A
^Bump
Old Jan 12, 2005 | 12:02 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
does the car have a carbeurator or TBI injection? they look very similar but the tbi is electronic.
if it is a true carb then it has had an engine swap done probably (at minimun swap from fuel injection to carb)
Old Jan 12, 2005 | 01:31 PM
Hal3246's Avatar
Axle/Gears: N/A
Would I look for something that is plugged into the carb? if it is electronic? I'll get pics of the engine up today.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
