tensioner removal?
Old Jan 3, 2005 | 06:47 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
tensioner removal?
Is it possible to safely remove the serpentine belt tensioner from the ac compressor bracket?
This may sound like a dumb question but it appears to be under a tremendous spring load and taking it off the bracket worries me.
BTW I do not want to delete the tensioner, just to remove it so I can clean up the support bracket.
Old Jan 3, 2005 | 09:55 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You generally don't remove it. Though, there is a big torx bolt in the center. That may remove it. Not something I would want to mess with, though.
Old Jan 3, 2005 | 10:22 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
:werd:
Even at the dealer where I work, if the tensioner is bad, we replace the whole thing. Then again, we've never wanted to clean it
Im trying to picture how exactly it looks, but my guess wud to just use like a Dremel and clean the hell out if, that shud be able to get into the tight spots without having to disassemble the tensioner itself.
Old Jan 3, 2005 | 11:05 PM
Engine: ZZ4 TPI
Thanks guys, but I'm dropping in a brand new ZZ4, I'm just trying to get all the pieces off my 305 that will be used again looking as good as new.
The bracket that holds the tensioner has about 14 years of crud on it.
Old Jan 3, 2005 | 11:10 PM
spills's Avatar
Car: 89 RS
PB Blaster is an old engine's best friend!
If it can get a siezed/rusted stuck piston out of a motor thats been sitting in a guys backyard for 2 years, i think a tensioner wud be a piece of cake
Old Jan 4, 2005 | 01:37 AM
Engine: ZZ4 TPI
Thanks again, but...
What I need to know (from those with experience) is, can the belt tensioner be SAFELY removed from the AC/AIR pump bracket so that I may have the bracket bead blasted.
Old Jan 4, 2005 | 05:50 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Yes, Once the belt is off of the serp setup there is no tension on the mounting bolt for the tensioner. It just unbolts. What the guys above were referring to was taking the two parts of the tensioner apart.
The mounting bolt is on the back side of the serp bracket if my memory serves me right.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
lakeffect2
Sep 7, 2015 03:52 PM
