PLEASE set my mind at ease........
Old Jun 17, 2001 | 02:00 AM
MATEOZ28's Avatar
I just noticed my oil pump shaft is a little loose at the bottom of my NEW angine. I was stabbing the distributer and had to turn the shaft a little so it would go down (normal) and when I touched it with the screwdriver it moved left and right about 1/8 of an inch back and forth. Is this normal? When the engine runs it has oil pressure ALOT actually as it is a high flow oil pump and never really noticed a drop in pressure at any rpm. Please tell me the moving shaft is normal or no big deal. Thanks
Old Jun 17, 2001 | 02:01 AM
MATEOZ28's Avatar
The 383 has approx 400 miles on it.
Old Jun 17, 2001 | 02:03 AM
MATEOZ28's Avatar
Old Jun 17, 2001 | 02:09 AM
Vader's Avatar
Mateo,
Go to sleep and stop worrying. The shaft needs to have some play on the upper end, since it is held on center by the distributor drive shaft. If the oil pump shaft were not allowed to move into alignment with the distributor, the pump shaft and distributor would wear out in a few hundred miles, if they lasted even that long without breaking.
The movement HAS to be there.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 17, 2001 | 02:10 AM
Vader's Avatar
BTW - How many miles are on the 383? (Just kidding)
Later,
Vader
Old Jun 17, 2001 | 02:34 AM
MATEOZ28's Avatar
Vader, thank you.
For years now you have been helping me out
If you ever want to come surf CA. let me know I got an awsome cousin with a house right on the beach and an extra board. Thanks again!!!!
and thanks to everyone else also.
[This message has been edited by MATEOZ28 (edited June 17, 2001).]
Azrael91966669
25
Jun 20, 2017 04:04 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
mustangdmurder
Aug 21, 2015 07:17 PM
kah992
Aug 19, 2015 02:55 PM
