Pulled Motor and Trans Today!!!!
Old Jun 16, 2001 | 04:43 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'm just so happy I had to tell everyone. Let me try to make this tech though. Umm....for everyone who wants to know if you take off your nose piece and remove the radiator and accessories, you can pull the engine and trans together.
Ok that's all.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Jun 16, 2001 | 05:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hmmm, I pulled engine and tranny together without removing any front accessories. Just took out the radiator. I kept my nose on & in-joint.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
[This message has been edited by five7kid (edited June 16, 2001).]
Old Jun 16, 2001 | 08:12 PM
Formula-91's Avatar
Yup. I did that too. Wasn't easy with the funky nose on a 91, but it worked.
Old Jun 16, 2001 | 08:39 PM
five7kid's Avatar
Paul, should add that I used a tilt sling. Couldn't have done it without it.
Also, congrats on your first pull. The "1st time" is special. Good luck with the 383.
Old Jun 16, 2001 | 11:09 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey Paul, I am not sure about the "pulling of the nose on your car" but way to go on your progress man! I guess it is coming along now. Looking forward to updates.
C-ya man!
Mike
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber.
Old Jun 16, 2001 | 11:58 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I wish I could say the same...The thrill of seeing my new motor on the stand is starting to wear thin
Good luck!
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jun 17, 2001 | 09:02 AM
Car: 89 IROC-Z
Engine: 383
The only reason I pulled all those parts is because I'm taking everything out of the engine compartment so it can be painted and it made it a lot easier to work in there. I'm also having my radiator support replaced. I still have a long way to go, but I'm taking steps forward now instead of backward. Next step is to clean up the bottom of the car and paint it with POR-15.
1992 Trans Am
May 10, 2023 07:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Bradsaundry
Aug 12, 2015 12:34 AM
1nastygta
Aug 8, 2015 07:38 PM
Leggman1
Aug 6, 2015 04:15 AM
