TRANS AM 2.8 V6 ACCORDING TO VIN DECODER?
Old Jun 16, 2001 | 11:47 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
hi guys i have a 82 firebird S/E and now i checked my vin in the vin decoder and here is what i got
1G2AX871XCN******
Trans am special Edition
but its a 2.8V6 2BBL
MAYBE IT WAS ORIGINALLY V8 ???HELP””
YOU CAN WATCH MY CAR ON READER RIDES
[This message has been edited by Vader (edited June 16, 2001).]
Old Jun 16, 2001 | 11:53 PM
Vader's Avatar
Sammy,
Sorry. I normally don't edit other people's posts, but you really shouldn't post your entire VIN on the boards. Some people can use the number for less-than-honorable purposes. The first 11 digits are all that is usually necessary to decode whatever information anyone might need on your vehicle. The last six digits are the sequence number, and are useless to anyone except those with bad intentions.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 17, 2001 | 12:05 AM
Vader's Avatar
Sammy,
Look closely at the VIN on your dash panel again. The number should start "1G2FX871...."
The "A" you listed in the fourth position might actually be an "F". If that letter were actually an "A", the following character would have to be either an "H", "G", or "F", none of which designate a RWD 'F' body vehicle.
The numbers should decode as follows:
1 - Assembled in USA;
G - General Motors vehicle;
2 - Pontiac vehicle'
FX - F BODY/SPORT 2 DOOR;
87 - COUPE-2 DOOR SPORT;
1 - Engine type;
X - Check digit;
C - 1982 model year vehicle;
N - Assembled in Norwood, Ohio.
The last six digits are the sequence number generated in the assembly plant to identify the specific vehicle.
Nowhere in the VIN is there a designation about the model conversion to a Trans Am. That specific information is detailed only in the RPO codes. Find the RPO label in your car and check those options and build instructions for more specific information. The RPO label is generally located in the center console, rear storage compartment, or on the left inner fender under the hood.
Later,
Vader
Old Jun 17, 2001 | 02:17 AM
Ovrclck350's Avatar
Made in: United States
Manufacturer: General Motors
Make: Pontiac
Restraint System: Manual belts
Carline Series: Trans Am Special Edition
Body Type: 2 door coupe
Engine Code: 173 ci V6 LC1 (1982-1984)
X is the CHECK DIGIT.
Model Year: 1982
Assembly Plant: Norwood
Production Sequence: Wouldn't you like to know
Hmm......weird.
Old Jun 17, 2001 | 02:42 AM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Ovrclck350:
Make: Pontiac
Model Year: 1982
Hmm......weird.
</font>
OVR,
Yes. Wierd. I don't have the "AX" platform designation in my cheat sheets. Usually the fourth digit is the platform designation, and we all have 'F' bodies, not 'A' bodies (Buick Century, Olds Cutlass, Ciera, etc.). The fifth digit is generally the variation of the platform, like sedan, coupe, hatchback, wagon, etc. A Trans Am is supposed to be coded "FW". A Firebird SE is coded "FX", which lead me to believe that he might have misinterpreted the fourth digit.
Now I'm confused. It's possible that South America has a different designation series, but the car was built at Norwood, Ohio. Go figure...
Then again, maybe things were done a little differently in 1981 and 1982, when it was built.
Later,
Vader
[This message has been edited by Vader (edited June 17, 2001).]
Old Jun 17, 2001 | 09:23 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
1982 is when GM started standardizing the VIN along with many other automakers. 1982-1984 Vins are not like ours. 1985 and later vins use the forth digit as "carline" whereas the fourth digit in a '82-'84 vin is the type of belts (in his case "A" being manual belts". Then the fifth character designates the carline. "S" was the base firebird, "W" was the Trans Am, and in his case, the "X" was the Trans Am Special Edition.
Why the "special Edition T/A" has a "1" (173ci V6) is beyond me, but GM has done stupider things.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jun 17, 2001 | 09:29 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
As GMTech points out, the "W" is a Trans Am and "S" is the base.
The "X" is an odd ball for the S/E and is not really considered a Trans Am. Heck, even GTAs had a "W".
tom1985
Apr 19, 2016 07:55 AM
383cam
Sep 9, 2015 06:01 AM
breathment
Aug 7, 2001 01:13 PM
Calderone
Jun 21, 2001 03:47 PM
Calderone
Jun 17, 2001 09:19 PM
