Is this a bad thing, or a REALLY bad thing?
Old Jan 5, 2005 | 01:16 AM
deadboyz's Avatar
Car: 1985 Trans AM
Transmission: AUTO.
Yesterday I removed the wheel well cover on my Trans Am, and for some stupid resone I stuck my hand in there blindly and I hit something, the next thing I knew i heard a really noticeable hissing sound like air was leaking out of something. After further investigation I saw that there is a small hose (about 2mm)that is disconneced from something. I put my hand inside the car on the drivers side, besides the side marker light (look and pic). What the hell did I do???!!!! How bad did I mess up? I would really like some help from anyone. PLEASE!!!
Old Jan 5, 2005 | 01:21 AM
deadboyz's Avatar
Car: 1985 Trans AM
Transmission: AUTO.
Pic...
Pic...
Attached Thumbnails Is this a bad thing, or a REALLY bad thing?-acfsirxny.jpg
Old Jan 5, 2005 | 01:31 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
sounds like you might have knocked the hose off the vaccum canister or broke it... should be able to hook it back up and be fine or have to replace something.. should be an access panel under there for access too.. or take off the plastic skin under the fender..
Old Jan 5, 2005 | 02:17 AM
Vader's Avatar
Yeah. Your ball no longer has your hose attached. I HATE it when that happens.
Old Jan 5, 2005 | 08:09 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
https://www.thirdgen.org/techbb2/sho...t=orb+of+power
originally posted by techsmurf
quote:
Originally posted by Doward
THE ORB... OF POWER!!!
:hail: :hail: :hail: :hail:
All hail the Orb of POWER!!! (insert latin chanting here)
Old Jan 5, 2005 | 08:42 AM
Damon's Avatar
You do NOT want to drive around with the hose disconnected from the Orb of Power. Trust me on this. It contains an artificial singularity that could become unbalanced and collapse the Orb of Power and everythign else within a 2 block radius. I had one implode on me several years ago. Fortunately this happened in an unpopulated area. The car was totaled and I woke up the next morning in a nearby field with my underwear on the OUTSIDE of my clothes and my legs sticking out of my ears.
Seriously, not big deal. That's just the vacuum reserve canister that supplies stored engine vacuum to the HVAC solenoids up under the dash to direct which vents the air comes out of when you move the selector on the dash. Reconnect the hose wherever you knocked it off of and you'll be good to go.
Old Jan 5, 2005 | 10:27 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You guys are too much!!! Even Mr Vader has a sense of humor!!!!
But seriously, you've got to reconnect or replace that hose. It will cause a major vacuum leak and engine driveability problem unless fixed. Could also cause other things to "break" (CAT, etc.) if driven very long that way (provided you could at all).
xxx3man`
Sep 23, 2015 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
