Tach is really off.....
Old Jan 6, 2005 | 06:09 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Comparing the tach in the car to the rpms that the ecm is reporting via ALDL, one or the other is VERY off. Idling at 750-800 rpm, my tach shows about 1100 or 1200 rpm. At 2000 rpm, the tach reads 2600. I am assuming the ecm figure is correct, and the tach is wrong. Is there any way to adjust or modify the tachometer so that it reads correctly?
Old Jan 6, 2005 | 06:15 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Check this thread, same problem fixed.
https://www.thirdgen.org/techbb2/sho...hreadid=272845
Tachs fail all the time on our cars, and always fail by reading higher.
https://www.thirdgen.org/techbb2/sho...ight=tach+high
Old Jan 7, 2005 | 09:43 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Is there a way to adjust it or compensate for the difference. In other words, fixing it so it reads correctly. Once I get the car dialed in, I don't want to be guessing as to when I need to shift. I also don't want to install an aftermarket tach in the car. I think it looks out of place.
Old Jan 8, 2005 | 01:16 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you have a manual trans, just shift when it stops pulling... thats when you wanna shift anyway.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
