Can timing cause a hot start problem?
Old Jun 13, 2001 | 08:48 PM
TwigBird89's Avatar
Yo sup My friends got an 88 GTA (we call it the Ghetto Trash Automobile cuz its such a ****). Anyway, hes got the timing way advanced (16* base timing showed on his neighbors diagnostic computer) I told him that probably why his car wont sart when its hot and he wont believe me because his "ASE certified" neighbor says that it needs a new starter, even though the current starter isnt even 6 mos old. Please prove him wrong guys... BTW we already wrapped the headers and replaces the neg. batt cable in case it was a bad ground, but still no luck...
Old Jun 13, 2001 | 08:49 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
does it click when it's hot... if so, shield the starter solenoid, too..
i would think of the car was more advanced it would start easier when the motor was hot, start easier, period..
Webmaster: www.IROC-Z.org
Old Jun 13, 2001 | 10:18 PM
jms's Avatar
jms
Too much timing can make a car difficult to start. For your GTA, if it is mostly stock, you should try to have no more than 8 to 12 degrees advance timing (I think stock timing is/was 4 to 6 degrees).
jms
Old Jun 17, 2001 | 02:49 PM
dude12387's Avatar
hey, its my car your talking about, and what i want to know is what corrilation does timing and starting hot have?
Old Jun 17, 2001 | 02:57 PM
Jason M 91Z's Avatar
haha, yo sup ghetto trash automobile. You sure you're from NJ?
-Jason M. 1991 Camaro Z28
Old Jun 17, 2001 | 06:58 PM
dude12387's Avatar
yeah, im sure, and im sure thats my car, so can anyone tell the what the two have to do with each other?
Old Jun 18, 2001 | 01:39 AM
Omar's Avatar
Why not just set the timing back to stock specs and see if your hot start problem goes away? It would cost you nothing.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jun 18, 2001 | 08:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
<font face="Verdana, Arial" size="2">Originally posted by dude12387:
hey, its my car your talking about, and what i want to know is what corrilation does timing and starting hot have?</font>
The farther advanced your timing is, the harder the car is to start. I had my distributer off by a tooth, and the starter wouldn't even turn the motor over. Anyway, when your car is hot, so is your starter. When your starter is hot, it is much less powerful. When the car is hard to start to begin with because of the advanced timing, the addition of heat soak can make it impossible to start.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 18, 2001 | 09:41 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The answer is yes, reason is you begin to ignite the mixture in the chambers too early and too low of an engine speed, there isn't enough engine speed to continue the piston through TDC, and the "pre-ignition" of the mixture causes the piston to stall.
Now is 16*BTDC enough to cause this? Maybe, maybe not. The easiets way to eliminate this as a cuase is to do as mentioned above, and set the timing back to a more reasonable setting.
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
