Anyone got a step by step for setting valve lash on full roller rockers?
Old Jun 17, 2001 | 10:25 PM
scauffiel's Avatar
I've done a search on it and have found conflicting advice - I just want to make sure that I do it right; as opposed to doing it over.
Darth Steve
Steve's Trans Am Temple
Old Jun 18, 2001 | 10:45 AM
ede's Avatar
ede
solid or hydrolic? if solid use the correct thickness gage and tighten the rocker down till the gage slides across the valve tip and roller. this all of which has to be done with the valve closed, you can look in your manual to see what valves you can do with out having to spin the engine over more than you need. for hydrolics set them the same as regular rockers on a hydrolic cam. loosen untill you hear a tick and then tighten another 1/2 to 3/4 turn.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 18, 2001 | 11:55 AM
scauffiel's Avatar
They're hydraulic roller lifters as well and I'll be setting it with the engine not running. So, if that's what you meant by "tick" (hearing them start to tick), how do you do it with the engine at rest? The usual "tighten it until you feel it start to grab, then 1/2 turn more?" Or do I use a feeler gauge?
Thanks for the help,
Steve
Old Jun 18, 2001 | 01:43 PM
ede's Avatar
ede
turn the engine till both valves are closed on each cylinder, tighten the rocker nut while spinning the push rod with you're free hand. when the push rod stops spinning tighten another 1/2 to 3/4 turn. best to set it up a little loose and use the engine running method after it fires up.
ICON Motorsports
1st & 3rd
Old Jun 18, 2001 | 07:42 PM
scauffiel's Avatar
Thanks brother - hope to fire her up this weekend!
Steve
Old Jun 18, 2001 | 11:36 PM
Joseph@SDSC's Avatar
This is the way I use at work to adjust all SBC rocker arms. First you need to put the engine at Top Dead Center(TDC) firing position for Cylinder #1.
With the engine in the #1 firing position the following valves may be adjusted:
-Exhaust 1, 3, 4, 8
-Intake 1, 2, 5, 7
Back out the rocker arm nut until lash is felt at the pushrod.
Turn in the rocker arm nut until all lash is removed. This can be determined by rotating the pushrod white turning the rocker arm nut. When the play has been removed, turn the rocker arm nut one full turn.
Now turn the crankshaft over one revolution. This should be Top Dead Center(TDC) for #6 cylinder firing position.
With the engine in the number six firing position, the following valves may be adjusted:
-Exhaust 2, 5, 6, 7
-Intake 3, 4, 6, 8
Use same procedure as above for adjustment.
I use this on all the old solid lifter cams I have used. You can also adjust them with the engine running if you can get the rocker covers off easily and adjust them with it running easily - if there is enough room to do it safely. I prefer the above method though cause its not as messy, and oil doesn't get on the exhaust and smoke forever. This may not work well with all camshaft profiles. It does work well for all stock style GM cams, and I used it on my LT4 Hotcam engines that I have built.
-Joseph
ASE Master Auto Technician
Scoggin-Dickey Chevrolet
Sunset RaceCraft
AOL IM: JosephSDSC
1967 Camaro (5.7L, Vortec Heads, ZZ4 Camshaft, GM Vortec Intake)
1992 Firebird (5.7L, Vortec Heads, LT4 Hot Cam, GM Vortec Intake, 3000 Stall, 3.73's, Auburn Posi)
Old Jun 19, 2001 | 09:51 AM
Scott C's Avatar
Joseph,
I bought and recently installed a new GM LO5/ZZ4 from SDPC. They installed a Crane cam and LT4 roller rockers before they shipped it out. It was shipped to me with the valve covers on. Should I be worried about having to adjust the rockers before I run it for the first time? I remember asking them if they adjust them and they said they did (and degree in the cam?).
'92 RS, ZZ4/LO5 10:1 350, Edelbrock 6085 heads, Crane 208/214* 467/482" 112* cam, GM/LT4 1.6 roller rockers, Edelbrock Hi-Flow TPI base, runners & 52mm TB, Accel 24#, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, 1LE driveshaft, SFC, Auburn Pro posi w/3.42, 17x9" ZR1 rims w/BFG tires, Medium Quasar Blue w/white SS stripes, Zaino...
Old Jun 19, 2001 | 06:36 PM
I'm not completly sure about the valve lash adjustment on that engine. I would assume it was done when the cam was swapped. Not sure on degreeing the camshaft. Thats not normal procedure for most crate engines.
-Joseph
Sunset RaceCraft
AOL IM: JosephSDSC
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
