Changing trans mount, urgent
Old Jun 19, 2001 | 08:26 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I cant get the inner bolt with a ratchet and can't get enough force with a wrench, can I take the crossmember off? or is that a real bad idea? basically is the crossmember holding the trans up?
i'm waiting to go back out on your response
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Old Jun 19, 2001 | 08:44 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Place a jack with a block of wood under the tranny pan just enough to hold it, and you could drop the x-member. Maybe a jackstand is a better idea if your jack leaks down and you will have it out for a while. The main fear is having it tip down and smashing your distributer cap off the firewall.
Old Jun 19, 2001 | 09:44 PM
Enkil's Avatar
You have to jack the tranny up some to free the tranny mount anyways.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 19, 2001 | 10:27 PM
Car: 92' RS
Engine: LO3
Well, the storms just quickly came in before I got much of a chnce to get to it. So I guess it will have to wait till saturday. So what is the best way to do this anyway? Jack up the trans a bit, take off the x-member and replace it?
Old Jun 19, 2001 | 10:35 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
That's the way I've always done it. Make sure you support the trans from the pan with a piece of wood. If you do it at the tailshaft you will have problems reinstalling the crossmember.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
maroe624
Apr 16, 2017 08:29 AM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
