Trick Flow on a 305
Old Jun 20, 2001 | 05:53 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
Trick Flow on a 305
I have heard on the G2 heads working on a 305. I have found the flow numbers to be 250+ intake and 200+ exhaust @.500" lift. I imagine that at some point you start to get too much flow capability and start to hurt performace. Does anyone know how much flow is too much for a 305? The heads can flow double what the engine can hold at 5750 rpm. (100% v.e.) Mostly concerned on a complete performance upgrade that has the engine producing peak numbers at 6000 rpm - hp and at 4500 rpm - torque. (90+% v.e.)
Old Jun 20, 2001 | 06:11 PM
Lounge Lizard 6's Avatar
I have never tried a set of G2 heads on a 305 and I think I remember Artie at Trick Flow say they won't fit. G1 heads will definitely work, though. I ran my G1 heads on my original LB9 for 50k miles with a Crane 2032HR and AFPR. It was a very nice combo.
Mike
'90 IROC-Z , 5-speed, ZZ4, G1 Trick Flows
Moderator SEThirdgen
LittleFranks
Sep 17, 2015 12:22 PM
Mickeyruder
Sep 2, 2015 02:45 PM
masonta
Sep 1, 2015 06:40 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
