What size sway bar do I have??
Old Jun 20, 2001 | 01:12 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
It's an 89 IROC-Z with a 305 and auto trans. I need to know the front and rear sway bar diameters.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Jun 20, 2001 | 02:09 PM
Spyder's Avatar
Need RPO Codes, you can get this from the dealer if you don't have them in the car. Should be in rear lock box or under arm rest.
Old Jun 20, 2001 | 02:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Instead of going to go to all the trouble of opening the console and finding the RPO and posting it and waiting, I think it would be easier to just take a micrometer out to the car and measure them. That's basically foolproof.
ICON Motorsports
Old Jun 20, 2001 | 03:17 PM
Mike-88CamaroTBI's Avatar
RB is right. There is an even easier method. I bet you have the required tools also.
1)Open your tool box or drawer and grab a manly size adjustable wrench and a ruler with cm on one side.
2)Walk to car
3) slide yourself under the car enough to clamp the adjustable wrench down on the sway bar then without loosening the wrench, pull it away from the sway bar and hold it up against the ruler.
4) the conversion factor is 2.2 cm/inch
So a 1.54" measured sway bar is 34mm
good luck
1988 Camaro Sport Coupe305TBI-4spdAOD-2.73open in "bought stock" condition. That'll change if it stays around here much longer mike.davis@firstunion.com
Old Jun 20, 2001 | 03:18 PM
2)Walk to car
good luck
Old Jun 20, 2001 | 05:16 PM
Bort62's Avatar
Mike
Your Camaro has a Ford AOD, interesting
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 20, 2001 | 06:38 PM
Car: 89 IROC-Z
Engine: 383
Ok I'll have to take those measurements tomorrow night after work...it's dark here now...damned rain. On the bright side I got all of my fuel and brake lines out today. The car is basically just a shell now.
Old Jun 20, 2001 | 07:35 PM
irocbsa's Avatar
Actually, the conversion factor is 2.54 cm per inch.
bsa
Old Jun 20, 2001 | 09:35 PM
You are so correct. The interesting thing about being over 40 is that you are positive you remember it right, but somehow or another some neurons cross connect and 2.54 turns into 2.2
Well I laid those two rules next to each other and you are absolutely correct.
2.54CM = 1"
Thanks for refreshing my memory
By the way my transmission is just a TH700R4.
I haven't ever wanted to cross breed a Ford and Chevy like that. Yuch!
However now that you have me thinking abaout it... it would be fun to slip a small block 400 and a M21 into my moms 1980 Pinto(she's 77, I'm 41).
"Hey mom .. I tuned up your Pinto. Be careful with the clutch, OK?"
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
m00n420
Sep 11, 2015 02:39 PM
87camaro87
Sep 9, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
