vacuum line sizes
Old Jan 16, 2005 | 02:58 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
vacuum line sizes
Does anyone know off hand what the size of the vacuum lines that go from the passenger side Throttle Body to the valve cover is? Or any of the vacuum sizes are?
Old Jan 16, 2005 | 11:28 PM
Vader's Avatar
The "hose" is actually a few pieces. There is a short section of 1/2" hose from the vacuum fitting on the TB to a 1/2" plastic tube. The tube is routed downward and backward along the valve cover. At the end of the 1/2" tube is a 1/2" 90 elbow that turns upward. This connects to another short 1/2" rigid tube that follows the contour of the valve cover to another 1/2" rubber 90° elbow connected to the valve cover breather fitting.
It is somewhat visible in this view:
Todd84Z
Sep 4, 2015 08:02 AM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
