HELP with Timing
Old Jan 16, 2005 | 03:20 PM
FLTraumaRN's Avatar
Car: 1988 Z28
Engine: 357 ci 472 hp at RWs
HELP with Timing
I have a 355ci with 465hp and I am finding it hard to time it also it acts as if it is loading up. I can get it to crank and run but putting a timing light on it, shows the engine is timed at 25-30 degrees BTDC and when I hook up the vaccum advance it shows 35 degrees BTDC. I am using a dampner that is 6 1/4 diameter instead of a 7 inch diameter does this hurt? I am Using a pete jackson gear set instead of a timing chain and it was aligned before install for TDC :hail: thanks Guys
Old Jan 16, 2005 | 11:15 PM
Vader's Avatar
The first step would be to verify the position of the timing marks.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
