cam install
Old Jan 17, 2005 | 09:29 AM
cutnsick's Avatar
Car: 88 GTA Pontiac right hand drive
Engine: 350 CI
cam install
what is the easist way to drop in a new cam into a 88 gta pontiac. do i have to lift or pull the motor.
Old Jan 17, 2005 | 09:35 AM
ede's Avatar
ede
i'd consider it, lot of people don't
Old Jan 17, 2005 | 10:24 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Pull the radiator and fan and all front accesories. It is definatly a weekend project
Old Jan 17, 2005 | 10:50 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
It can be done with the engine in the car. The only point you really (well, not really, but you can) lift the engine would be to lower the front of the oil pan to clear the lower lip of the timing cover.
Old Jan 17, 2005 | 11:20 AM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
Like said before, radiator, and all the crap in front of the hole that the cam shaft goes in. Also have to remove the valve covers to loosen the pushrods, then remove the intake manifold so you can remove the lifters.
Like said before it really is a weekend job.
As much as you have to do for a cam swap, I would suggest waiting untill you can change things like lifters to 1.6's and such to maximize your swap time.
Old Jan 17, 2005 | 12:59 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Might as well do a two piece timing cover as long as you are down there too. Make sure to get an aluminum one, they seal much better.
Old Jan 17, 2005 | 03:21 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
DO NOT pry the timing cover off of the oil pan lip and then cut the cover to slide back on. To do it right you will need to drop the front of the pan.
Old Jan 18, 2005 | 08:38 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Which is why everyone should buy a two piece timing cover.
Old Jan 18, 2005 | 09:20 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Agreed.
I'm looking for one myself, but don't want a chrome one.
-- Joe
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
