will HP waterpump help cooling?
Old Jun 20, 2001 | 08:40 PM
dsavio's Avatar
I have a new 350 in my camaro and it seems i have a overheating problem even with the fan on the temp continues to rise.worse at idle.
it is a new engine and im thinking of buying a new victor series pump will this help?
Dave
Old Jun 20, 2001 | 10:39 PM
Enkil's Avatar
I'd first check the radiator, see if it's not blocked off, or rusted.
Then check the condition/level of the coolant.
Then, check to see if the thermostat's not stuck.
THEN you can check the water pump.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 20, 2001 | 11:36 PM
dsavio's Avatar
I have a new radiator
Checked fluid level
new Fan motor (fan itself could be out of round if this matters?)
new thermostat 180
New Stock kragen pump lifetime warranty ( doesn't mean its not junk)
Engine putting out about 350 Hp
Old Jun 20, 2001 | 11:38 PM
dsavio's Avatar
I'm thinking the new stock pump and fan won't keep up with the hp motor?
Old Jun 21, 2001 | 12:21 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I had all new stuff just like you, and couldn't keep my 350 cool either. I swapped the lifetime warranty POS water pump out for a Stewart Stage1 pump www.stewartcomponents.com along with one of their high flow thermostats (same temp stat as before though) and have been very happy. Runs nice and cool now...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited June 20, 2001).]
Old Jun 21, 2001 | 10:22 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
What mix of water/AF are you using. Try 70/30 water/AF , or even more water. I have seen several cars that would run hot b/c of stronger AF mixes.
Also, is your radiator cap new? If not replace it, cheap insurance. This is always the first thing i replace on any car i buy, just because i have had way too many strange cooling problems caused by faulty caps.
Check those 2, then worry about a new WP.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jun 21, 2001 | 12:22 PM
dsavio's Avatar
Thanks for the input i will get the new water pump and i already have a new radiator cap.If that doesnt do it i will get a better fan just keep on keeping on.
dave
Old Jun 21, 2001 | 03:45 PM
mrgto's Avatar
A little bit more info is needed. What year is the car, what engine was in it before the 350. What year is the 350. Etc.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
