Speedo?
Old Jun 21, 2001 | 04:49 PM
92Camaro305TBI's Avatar
Speedo?
My speedo stops at 110........... So does my car.. why is that.. the govenor or whatever.. Also how would I remove it so I take my car to its full potential when racing...?
92 Camaro 305 TBI Automatic. 2.5 high flow cat and 2.5 pipes into3.5in tip, shift kit. Tinted windows(legal)...
Future mods. Spark plug wires and plugs, Headers, O.E., any other advise on getting to 300+ HP would be appreciated. Thanks
System = Sony explode CD/MD receiver, Rockford 6x9 Fanatics, 4x6 Clarion in the front, 2 12" Hx2's(Rockford) in custom box(black carpet) 1 farad cap, 800x2= 932 total watts Rockford Amp 4gauge wire kit.
Old Jun 21, 2001 | 06:43 PM
Enkil's Avatar
Ahh, you're hitting that wonderful speed limit built into all 305 tbi's. There's a value in the ECM set to around 110, or thereabouts. The ECM gets it's info from the VSS (vehicle speed sensor). If you disconnect that, then the computer won't know to cut the fuel off at that speed. However I think the TCC can't lockup if you disable the VSS, so you'll have to put a switch to do that manually.
The VSS was probably just put in there for a safety reason, as all cars with 15" non z-rated tires also got that limiter. There's a tech article on how to disable it.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
