VSS?
Old Jun 21, 2001 | 02:44 AM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
VSS?
Does anyone know where the VSS is located in a 91 L98. My buddy's speedo stoped working and we got the code for the VSS.
Old Jun 21, 2001 | 12:40 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Hmm . . . code 24? I think the sensor itself might be near the tranny conv. clutch connector. (underside of engine/tranny, driver's side) That's strictly a guess though. Maybe you should try this post on the electronics board.
Old Jun 21, 2001 | 07:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If electronic speedo, it's in the tailshaft housing where the cable used to connect for mechanical speedos. Failure would cause the speedo to quit working, which also means the VSS is out.
If a mechanical speedo, it's on the speedometer itself where the cable goes into the speedo. For both the speedo to quit and throw a VSS code, the cable would have to stop spinning the speedometer.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
[This message has been edited by five7kid (edited June 21, 2001).]
Old Jun 21, 2001 | 09:24 PM
trebor91's Avatar
If you need a new VSS, I got one. I got it from GM when I was redoing my speedo gears during my 3.73 swap. If your interested email me at trebor07@home.com.
1991 Camaro RS, 305, Chevy 3.73's, Auburn Pro Posi, March Underdrive Pulleys, K&N Open Element Filtercharger,
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
