not good cold ((stalls) did tune up didnt help)
Old Jan 18, 2005 | 02:04 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
i have an 1985 trans am that isnt running good cold (sometimes stalls)and it runs rough warm. it isnt misfiring i did a full tune up and it still isnt right i just bought the car a month ago so it is really frustrating, please help.. things i did: new: MAF sensor, wires plugs, pcv, fuel filter, oil change/ filter, air filter, electronic spark control module, distributer cap and rotor, It is leaking oil but not sure where it is coming from. PLEASE HELP
Old Jan 18, 2005 | 09:26 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Try a new O2 sensor? They are cheap enough. A sour O2 can cause lots of weird running problems, **but only when the engine is warm.
Old Jan 18, 2005 | 09:29 PM
Engine: 388 Carb
Axle/Gears: 4.10
thanks ill have to try that
Old Jan 19, 2005 | 04:14 PM
Engine: 388 Carb
Axle/Gears: 4.10
o2
Will I be able to tell visually if the o2 sensor is bad?
What are some side effects of a bad o2 sensor?
Where are these RPO Codes located on the car, will they be printed on a peice of metal or paper?
Old Jan 19, 2005 | 04:34 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Re: o2
No
car runs rich or lean, I believe they usually fail lean
Usually listed in glove box in counsel or in rear glovebox in hatch area
Old Jan 20, 2005 | 02:10 PM
Engine: 388 Carb
Axle/Gears: 4.10
o2
thanks I put in a new o2 sensor and it runs much better it still idles a little high but now i think the timing is off so i will have to do that tommorow thanks alot for all of your help
::I dont have a glove compartment::
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
ezobens
Aug 19, 2015 10:29 PM
drathaar907
Aug 6, 2015 04:20 PM
