Is 220-225/230 overheating?
Old Jan 18, 2005 | 09:13 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
My car is an 82 TA, 305 LG4 Q-jet, no overdrive with 3:73s.
With a 195 t-stat, the car gets up to 220 on the freeway(55-70 mph) around 3 grand on the tach. With the heater on, sometimes it comes down. The ambient temp ranges from 0-20 degrees right now.
One mechanic said it's fine, it's in the middle of the temp gauge. Right now the car gets around 11-14 mpg, he says if I were to put in a 180 t-stat, it would be around 10. Another mechanic said 220 is hot.
I asked if a colder spark plug would make a difference, and was told only a few degrees.
Old Jan 18, 2005 | 09:21 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Our cars are designed by GM to run hot to aid in emmisions. 220* is normal. I'd be worried if it were 240-250* Around 260* they will start to overheat.
Old Jan 18, 2005 | 09:24 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A 'colder' spark plug wouldnt make any difference here, from what I've been taught about what 'hot' and 'cold' mean. Basically, its not 'hot' and 'cold' in relation to actual water temp, but more or engine setup.
Anyway, 220 is not too hot. Ideal running temp is usually around 210*, so I wouldnt worry about it. Its warm, but its not hot.
Old Jan 18, 2005 | 09:42 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
my car all summer ran at 170 and that was on my aftermarket gauge.
Old Jan 18, 2005 | 09:53 PM
Air_Adam's Avatar
Good point... my factory guage is buggered and reads high too... forgot about that... the factory guages suck.
I suggest buying a mechanical one (mine was like $10), hook it up in place of the factory sending unit, and see what the temp REALLY is.
Old Jan 18, 2005 | 11:53 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Does it only get hot on the freeway? What about at an idle? Check and see if your air dam is in place underneath the nose. Without that, youre sure to run hot.
Old Jan 19, 2005 | 12:05 AM
nidyanazo's Avatar
I purposly removed my air dam and all that plastic shrouding. My car runs at ~195-205* :shrug:
Old Jan 19, 2005 | 12:17 AM
84L69TA's Avatar
Car: 4 Mopars total
Why would you remove it???
Old Jan 19, 2005 | 12:44 AM
nidyanazo's Avatar
Well, first I didn't like the look or it hanging out from under the car. Then I didn't like the way it looked when you look at the rad. It seemed to me like it would be more effecient if the air had more surface area to be distributed over, instead of having to pass through those 2 "tunnels" to get to the rad. So I chucked it. And for me it worked, lowered temps ~5-10* Idle, hwy, wot, whatever.
Old Jan 19, 2005 | 11:08 AM
Damon's Avatar
Before you decide what to do, replace the temp sender that runs the gague. It's between the #1 & #3 spark plugs on the driver's side of the engine. The senders can get whacky over time. Not that this will definitely make the gague read accurately (it's only 1/2 of the equation- the cheap factory gague itself is the other half) but it's worth a shot for $10 and a little wrench time.
Gague in my wife's 92 regularly reads somewhere between 5 and 15* hotter than the CTS sensor, which the ECM uses to measure actual engine temp. ECM says the engine is 205, gague says 220. Both new senders. It happens.
Old Jan 19, 2005 | 11:25 AM
12secformula's Avatar
Car: 94 Z-28
220 is not that hot, most of the thirdgens run that hot. Plus I believe that the second electic fans doesn't even turn on til like 225, if i remember corrrectly.
Old Jan 19, 2005 | 12:30 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Don't trust the gauge. My '88 IROC says 220° but it's actually 40° off, the actual temp is 180° as read from the ECU.
Old Jan 19, 2005 | 01:32 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Its a Q-jet, so the coolant sensor is right above the t-stat. It was replaced when the check engine light came on, some time around 9 months ago??
Old Jan 19, 2005 | 07:58 PM
Damon's Avatar
OK, I could be wrong about the temp sender location on the older carb'ed engine. Just make sure you're actually replacing the sender that runs the gague (it's only got 1 wire going to it), not the Coolant Temp Sensor (CTS) that talks to the ECM (it's a 2-wire sender with a weatherpack connector). Even on the old carbureted engines there are 2 different senders.
Old Jan 19, 2005 | 08:56 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
TransAm12sec, the temp sensor for the gauge is on the drivers side head. There is one single green wire that connects to it. Look down by the exhaust manifold. The temp sensor you replaced is for the computer.
230 degrees is definately hot for the old engine driven cooling fan cars. My '84 LG4(and 71 and 73 T/A) runs all day long right around 200-210 degrees.
Old Jan 19, 2005 | 09:11 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Is 220-225/230 overheating?
im gonna be the first to call on this one. how does watertemp have anything to do with fuel mileage? granted i have an od tranny, but with a holley on top and 4.10's out back and a 160* stat, i see about 20-22 highway mileage. i use an electric fan from a v6 in my car and never see above 180* temps.
Old Jan 19, 2005 | 09:46 PM
Cali Z's Avatar
hmm. I couldn't drive my car 10 min without it overheating, with a missing airdam. Install airdam, and instantly, car runs normal. I wonder why such a difference?
Also, for a stock sbc in our cars, I read that 220 w/iron heads is optimal normal operating temp. for these cars. Am I incorrect on this? I installed a toggle switch wired to the electric fan in antisipation for 100 + degree days in summer, but other than that, why do so many people want their cars running so cool, (excluding aluminum headed engines, i know they need to be under 220 granted warping temp).
Old Jan 19, 2005 | 10:06 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
I thought your car had a mechcanical fan and if that is the case it could be the thermal fan clutch.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
