If my car sounds like a diesel truck is that bad?
Old Jan 20, 2005 | 09:48 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
YES IT IS!!!!
So i had a little fun in the snow, doing doughnuts, Didnt really over rev at all except once into 4000...which still isnt bad. But about half an hour after that I drove my buddy to work, the second he stepped out of the car.....its just wants to stall, then goes into deisel mode....yeah....as loud a a cummins truck...same sound and everything....
So i pull into the parking lot....turn off the car and pop the hood. Start it again, really hard to start....then mur mur mur brrrr (deisel sounds)....loud as hell....i was like covering my face cause im embarrased of my cummins camaro.
Luckily my other friend that was following me at the time had 2 liters of oil (5W30) so i put that in, gets a bit better, but still hard to start. Then after stalling and starting again, it went back to normal.... like wtf So i made it down the highway (thank ***) and got back home.
What the hell happened, I was scared to ****. I just couldnt beleive the sound. If a semi truck came by I could compete with him for loudness......it was awful
To be on the safe side should I get some engine restore? Also, forgot to mention I have a small oil leak, So wouldnt the engine restore just leak out anyway?
Thanx
Curtis
Old Jan 20, 2005 | 10:42 PM
EvilCartman's Avatar
Car: '82 Z28
Do an oil change and check to see if your oil looks like metallic paint with all kinds of sparkly bits in it. How's the oil pressure? I burnt up a Nissan motor when doing donuts in the gravel when the oil was really low. Best guess is it sucked the pan dry and that's all she wrote. That motor lasted almost 10 years before some other kid just recently blew it up again.
Old Jan 20, 2005 | 10:49 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
lol you need to watch your oil levels a little more closely if it will take 2 litres like that. But think about it.. the oil shouldnt make the exhaust louder like that. And I dont think it could have been an exhaust leak, because it went back to normal.. Wow. That's a real head scratcher.
Heh I was out really late playing with my exhaust cutout and it got stuck in the full open position.. you think your car was loud.. try trying to sneak home with open manifolds...
Old Jan 20, 2005 | 10:50 PM
Car: 1987 Z28
the oil pressure was around the middle while normal driving. But yeah why would doughnuts be bad? its just like driing but spinning the tires....cause i wasnt over reving it
Old Jan 20, 2005 | 10:53 PM
Car: 1987 Z28
thats the thing....it wasnt the exhaust....the engine made the sound
and lol yeah....ive heard cars with open manifolds....lol...watch out
Old Jan 20, 2005 | 10:58 PM
305q_ta86's Avatar
Transmission: 5 spd
The engine? oh ****.. Go get that v8 in there now. :P
spun bearing? rod knock? maybe it's a wrist pin, or something in the valvetrain got owned. I still cant see why it would have gone back to normal though. My bet would be on the valvetrain though.
Old Jan 20, 2005 | 11:32 PM
Car: 1987 Z28
yeah dude it was some weird ****, my first though was a push rod or rocker
lol you put it good, something DID get owned
Old Jan 20, 2005 | 11:48 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Im guessing oil pan got sucked dry, think about it, your doing donuts, all the oil is shifted to one side of the oil pan.
Old Jan 20, 2005 | 11:50 PM
Car: 1987 Z28
but this happened about 30 minutes after
Old Jan 21, 2005 | 03:48 AM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
But the damage would have already been done. It doesn't take long to wipe out the bearings. I'd stop worrying about it and drop in a 350.
Old Nov 11, 2018 | 10:28 PM
Turless's Avatar
Re: If my car sounds like a diesel truck is that bad?
OK so like 5 months ago I was driving my Camaro z28 and I hopped a curve and then the next day it sounded like a diesel engine OK so yes I do have low oil pressure but I been working on the opti and ICM but those haven't changed the sound of it So I'm asking like how did you fix your problem??
Old Nov 16, 2018 | 10:07 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
OK so they haven’t logged in here in ELEVEN years OK so this thread is nearly 14 years old.
Old Nov 16, 2018 | 07:23 PM
NoEmissions84TA's Avatar
You forgot to add a few "likes" in that sentence. It should read more like this so the youngsters today can understand it:
Like OK so they like haven’t logged in here in like ELEVEN years like OK so this thread is like nearly 14 years old.
Terrell351
Jun 13, 2021 01:13 PM
B_Dubya
Aug 26, 2015 05:09 PM
squiggy2
Aug 9, 2015 09:30 PM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
