Can't figure this noise out :(
Old Jan 21, 2005 | 12:14 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I changed the rockers, changed the lifters, changed the pushrods and I still get this nasty clacking noise. Its very very quite at idle, but very audible the minute it goes past 900 rpm. I recently installed a cc306 and it was running fine for 2 days. Oil pressure is extremely good, 60 psi at cold, 27 at warm, no fluctuaction what so ever. I hear it mostly on the drivers side and I can't figure this out, I thought at first it was the lifters, changed those, changed the pushrods, and now the rockers and its still there. It doesn't sound like a rod because its coming from up top. All the rockers are getting really good oil and it smokes the hell out of my engine bay if im revving it (oil gets on headers). I've had people come by and look at it and they say it sounds like valve train. My father in law said it might be a cam bushing but I don't this LT1's have cam bushings. I havn't driven it since it has happened but when I did I could feel vibration in my clutch pedal. When I pulled the lifters I cleaned my hands and put some oil on them and stuck my fingers in the lifter valley's to check the cam lobes and all felt great to me. Im stumped on this one guys, can someone tell me what is going on?
Old Jan 21, 2005 | 12:47 PM
pasky's Avatar
Old Jan 21, 2005 | 12:52 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Leaky headers? Maybe a noise from of of the accessories?
Old Jan 21, 2005 | 12:54 PM
pasky's Avatar
No, checked the headers also. This sounds like metal hitting metal. There are no metal shavings in the oil either. Nothing wrong with oil pressure. I changed the entire valve train out and I just can't figure this out .
Old Jan 22, 2005 | 08:24 PM
Karr1986's Avatar
Car: 1986 Pontiac Firebird
Engine: 173, 2.8litre MPFI V6
I have a similiar problem in my v6. To me it sounds like its is comming from the fuel rail. I'm not sure of what the problem is but I would love to know the answer as well
Old Jan 22, 2005 | 09:19 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Are replacement rockers self aligning?
Old Jan 22, 2005 | 09:36 PM
pasky's Avatar
Yes, found out it was the cam bearings, the bushings on the cam are scratched on the front and back. The cam bearings look extremely copper colored.
Old Jan 22, 2005 | 09:44 PM
Lo-tec's Avatar
That sucks. Good luck getting it fixed!
Old Jan 22, 2005 | 09:48 PM
Car: 87 Firebird
Engine: 5.3 76mm
Hmm well good thing you found it, hope the oil is in good shape and that you dont have metal anywere in the block, unfortunetly i would recomend a full rebuild so that u dont get taht stuff worked into the mains and rods, but the bearing replacement isnt too bad on the cam, jsut get an install tool ~60-80 bucks, or maybe able to rent one, kind of pricy for 3 bearings though
Old Jan 22, 2005 | 10:30 PM
pasky's Avatar
Yup, i caught it extremely quick, happened in a parking lot about 1/2 a mile from my house, drove it straight home and it hasn't moved in 2-3 weeks. Like I said, got a brand new block 15,000 mile in the back of my truck that im just gonna swap my top end on to and rebuild the old block into a 383 . Oil had no metal what so ever. The cam bushings are scratched really bad on the front and back. One has a small groove in it. I've been wanting to port my heads anyways .
Old Jan 23, 2005 | 04:26 PM
onebinky's Avatar
Just an FYI, I just got a cam remover/installer tool on EBay for $49 shipped. Appears to be a decent quality tool, but it is only fitted for SBC bearings. Should be getting it around wednesday
Any idea on the quality of the bearing sets you can pick up at the parts houses for ~$20?
Old Jan 23, 2005 | 04:56 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You have an LT1, so I assume serpentine belt? Take off the belt and check your pullies, you might have something like your waterpump or PS, or even your alternator going out. They usually whine when they go bad, but my alternator clacked and banged like a biatch before it finally gave out. It was just worn out, and the pulley had lots of play in it, and thats where the noise was coming from.
Old Jan 23, 2005 | 05:39 PM
pasky's Avatar
It wasn't whining, it was knocking.
Old Jan 23, 2005 | 10:17 PM
Air_Adam's Avatar
Yes, thats what I said mine was doing.
Old Jan 23, 2005 | 10:55 PM
12secformula's Avatar
Car: 94 Z-28
Cam bearings.....wow, that sucks man. Good luck getting it fixed. Are you gonna do more than port those heads and a cam swap while its out? By the way, I wanted to thank you for your help in the post "me versus 69 Mustang", I got a CC306 cam and am working on stroking my engine to a 383 before spring. I want to demolish that mustang!!! Anyways, I'm glad to hear that you found it early, before anything else went wrong.
gta892000
Aug 11, 2019 11:16 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
64Chief
Sep 12, 2015 08:05 AM
luvofjah
Sep 10, 2015 10:41 AM
Randomtask2
Sep 7, 2015 05:06 PM
