WHAT DOES PINGING AND KNOCKING SOUND LIKE?
Old Jun 22, 2001 | 11:36 PM
matty350TPI's Avatar
Hi yes a stupid question I bet and I am a novice. I just want to know what I should be hearing. What do they sound like and do the affect the performance. Please enlighten me. Thanks
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch, Spohn Sub-frames, Jamex 1.5 Lowering springs, 2 1/2' Exhaust,ram air setup
Old Jun 23, 2001 | 06:53 AM
ede's Avatar
ede
most people refer to it as the valves rattling.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 23, 2001 | 10:13 AM
Bort62's Avatar
Sounds like Something Hitting your Fan.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 23, 2001 | 12:32 PM
rondubbs's Avatar
if your knock sensor detects pinging it will retard timing , affecting performance.
Old Jun 23, 2001 | 03:40 PM
CamaroZ_85's Avatar
it sounds like a woodpecker in your motor, just not as hollow....you'll hear it best w/ the radio off, the windows up, and no air/heat on....it's a nasty sounds and you'll know it if you hear it.
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Jun 23, 2001 | 03:47 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I had an RS with a 406 and TBI trying to get that thing to feed the motor was fun. It dentonated so hard one time it sounded like someone was beating the piston top with a hammer. Its not a pretty sound...
Make sure your exhuast is leak free around the motor. Some times a leak can sound like pinging.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jun 23, 2001 | 08:24 PM
Dan87IROC-Z's Avatar
Put a screw driver in a tin coffe can and shake it around, thats what detonation sounds like.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
wanext
Oct 6, 2015 12:18 AM
efiguy
Sep 27, 2015 01:30 PM
