Anyway to replace cam bearings while their still in the car?
Old Jan 22, 2005 | 05:10 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Old Jan 22, 2005 | 05:20 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
No. The last bearing will need to be taken out in the rear.
Old Jan 22, 2005 | 05:21 PM
pasky's Avatar
so gotta pull the pan?
Old Jan 22, 2005 | 05:24 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yep, gotta pull it out of the car and pull the oil pan.
Old Jan 22, 2005 | 05:49 PM
pasky's Avatar
Can't just pull the transmission, pop the freeze plug and change it there?
Old Jan 22, 2005 | 05:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I don't think there's enough room between the block and the firewall.
Old Jan 22, 2005 | 06:47 PM
pasky's Avatar
Screw it, im pulling this bad boy and porting the heads, already got the damn thing torn down anyways.
Old Jan 22, 2005 | 07:03 PM
ede's Avatar
ede
pretty much have to do it with the engine up side down as well as having the pan removed and the cam plug removed
Old Jan 22, 2005 | 08:46 PM
pasky's Avatar
Alrighty. I got a new block, 15,000 miles im gonna use instead, fully assembled and ready to go. Gonna have the cam checked by a machinist and get new cam bearings to fit it if the cam needs to be turned and just put them on the new block. Gonna port my intake and heads too. I got a spare intake and spare iron heads, so if I mess the aluminums up, i'll put the irons on until I can find a set of aluminums again. This is sort of a good thing. Now I can clean my wiring up, paint my block and paint my intake.
Anything else I should have checked?
Old Jan 22, 2005 | 09:31 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Ya gotta be relentless
Old Jan 22, 2005 | 09:34 PM
pasky's Avatar
When **** breaks, it means its time to go better
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
gwade12
Aug 8, 2015 08:17 AM
rsrmoore
Aug 7, 2015 08:44 PM
