L98 Heads with a Flat Tappet Cam
Old Jan 23, 2005 | 04:28 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
Will there be any complications with using 1989 L98 heads, all stock except for the springs and studs, and a mild aftermartket hydraulic flat tappet camshaft? Will I need different rockers or guidplates?
Old Jan 23, 2005 | 05:37 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
No problems, just remember to get some pushrods for a non roller cam.
Old Jan 23, 2005 | 09:35 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Those heads will have press in studs, no problem there. They are set up for self align rockers with the larger holes for the pushrods through the heads so you'll either need to pull studs, thread for screw in rocker studs or just stay with the self align rockers. Still no problem either way. Should work fine. Pretty good small chamber heads.
lt500r55
Sep 1, 2021 01:30 PM
beastin91rs
Oct 9, 2015 07:38 AM
camaro71633
Sep 1, 2015 10:24 AM
hayesaw0210
Aug 23, 2015 11:15 PM
anesthes
Aug 8, 2015 09:37 PM
