help with evrything under the hood
Old Feb 4, 2005 | 09:54 PM
bilzhar's Avatar
Car: 89 firebird & 85 trans am
Engine: both 305's
Transmission: auto
ok i bought this 85 trans am with a fresh rebuilt motor. have had problem after proble with it but have finally got it on the road..replaced the alt. , replaced the fuel pump, only to find out the gasket in the carb were shot to hell went to rebuild stock qjet to find that who ever rebuilt it before me forgot to install some much needed parts and gaskets and o rings inside so i scraped the qjet and went to a edelbrock 600 . Now runs pretty damn good....but its a mess under the hood the ac was riped out by what looks like a bunch of 10 year old kids knawing at it with there teeth.. wires every where broken sensors just hanging there..still dont know what to do with the qjet connectors...i can take pics and email them to anyone that can lend a hand...i need to know what i can do with the wiring and vacum lines cause im sure they arnt all in the right places. What can i do with the distributor, coil, and everythnig with that? Dont know where to satart but willing to try anything and everything.
thanks guys,
Bill
Old Feb 4, 2005 | 10:15 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
well if that was a cc qjet then you should have a cc HEI cap also so i would replace that for starters. then i dunno
Old Feb 5, 2005 | 12:07 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Man, that looks nasty. Decide now if you want to keep the CCC controls (computer) or not. By looking at the nice shiney carb, I'd guess the computer isn't a concern?
It'll take a bunch time and patience to figure that wiring out, but not impossible.....
My computer and ECM harness are hanging from my garage wall on a pegboard hook....
But it ran great with the 305HO in it.....and I still had the
CC Q-jet and 50 state legal!! The 305's on a stand waiting...
Old Feb 5, 2005 | 03:23 AM
sellmanb's Avatar
Car: '86 Berlinetta
Haha...
first thing I would be buying is wire looms, then bring in all the broken sensors while you're there, and be like "I need new ones of... -throw sensors on table-... these... ".
That is unless you're ditching the computer. Then just start pulling out all of those sensors and weed through the wires you dont need then lol.
I guess if it were me, it would be a lot simpler for me to just rebuild the q-jet myself, and then plop it back on so I wouldnt have to mess with buying a new distributor, and figuring out which wires I need to pull, then take out the ECM, then I dont know if the ECM sends a signal to the gauges to tell you the tach signal, or the speed... so that might be a mess all in itself.
So if it were ME... rebuild the Q-Jet the right way. Replace sensors, and get wire looms... lots, and lots of wire looms lol.
Old Feb 5, 2005 | 03:52 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Hes got the correct distributor. I see the vacuum canister poking out of its side. No issues there. Just a simple tach and power wire.
Go ahead and send me some pictures if you want. We'll see what can't be done.
Old Feb 5, 2005 | 06:05 AM
bilzhar's Avatar
Engine: both 305's
Transmission: auto
I am not interested in the comp
But i need to know what to do with it.....
Ill get on those pics this morning..
thanks
Old Feb 5, 2005 | 07:25 AM
bilzhar's Avatar
Engine: both 305's
Transmission: auto
ok put a few pics on a web page..let me know what you think i can do..
http://www.geocities.com/ladyandbilz/wiremess.html
thanks,
bill
Old Feb 5, 2005 | 11:29 AM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
first re wire you spark plug wires and get them ethier out of the way or mkae them look nice. then take all the ries that arne't conected to anything and justbunch them together find were they come form and then do what you like
Old Feb 6, 2005 | 10:01 AM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
What are these two things in the pic and what do they do.
Attached Thumbnails help with evrything under the hood-c-documents-settings-john
Old Feb 6, 2005 | 11:06 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
parts under hood
#1 is a vacuum reservior. You need that to operate your a/c-heater-defrost controls.
#2 looks like a MAP (manifold air press) sensor. There should be a vacuum line running from it to the intake manifild. You'll need that if you want the computer to know how much load is on the eng.
Old Feb 6, 2005 | 12:16 PM
bilzhar's Avatar
Engine: both 305's
Transmission: auto
vacuum res..what does it run from casue right now vac line is just hanging there...
map sensor (#3) ? its not hooked up to anything. The only line coming from the manifold is in the 2nd pictue....What is that?
1st pic what are #1 and #2?
thanks...
Bill
Old Feb 6, 2005 | 12:18 PM
bilzhar's Avatar
Engine: both 305's
Transmission: auto
whats this?
Old Feb 6, 2005 | 01:40 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
in the last pic thats you map sensor see how a vacum line goes form your intake to the senssor that cause it messures diffrenace in pr3ssure form out side are to air in the manifold. no clue waht the others are
Old Feb 6, 2005 | 01:59 PM
bilzhar's Avatar
Engine: both 305's
Transmission: auto
1 down many many more to go....
Ok how about the vacuum reservoir what does that run off of?
ok how bout the cc what do i need to do to get rid of it? What do i have to change?
thanks,
bill
Old Feb 7, 2005 | 07:48 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
After seeing the last pic, I agree, that is the MAP sensor next to the dipstick. Not sure what that is on the far left side (#3 in next to last photo). Is that a vacuum line coming off the bottom??
Item #1 in that same pic is the ESC (elec spark control) module. On later years, it was replaced by some circuitry on the Memcal.
Item #2 is a relay.
On my car I have 3 identical relays in that same area. Fuel pump, MAF power and MAF burn-off. Since your car has no MAF (mass air flow), I'm assuming that is the fuel pump relay.
The vacuum reservoir connects to intake manifold vacuum via the large line. (If you're not going to use the computer, the vacuum reservoir could connect where the MAP sensor is connected) The small line should be going to the inside of the car. The vacuum provides the muscle to control where the air comes out (defroster, heater, A/C vents, etc). If vacuum is lost, air should come out the defroster vents only. This is its' default mode. For safety reasons you want the windshield clear.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
