How well will an a/f gauge work on a non cc carb?
Old Feb 6, 2005 | 01:49 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
just as the title says.. I've done some mods to my engine to help it breathe better, and now I need to make sure I dont lean it out. So I just need to know if I will get a useful reading from it, or if there is a better way.. (and no $500 wideband ones for me)
Old Feb 10, 2005 | 04:40 PM
Vader's Avatar
An EGO analyzer would work. They were part of the old Sun 720, 920, and 1120 machines way back in the early '70s. I remember using them on plain old carbed engines.
Old Feb 10, 2005 | 04:58 PM
305q_ta86's Avatar
Transmission: 5 spd
Ok, I might try that.. Now to find where I can get my hands on one..
Old Feb 10, 2005 | 06:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
As well, or as poorly depending on your choice of gauge, as it would work on a OBD2 car.
A/F is A/F; whether it's FI or carb, whether the carb is computer-controlled or not, or whatever. It's a physical reality.
Old Feb 10, 2005 | 10:37 PM
305q_ta86's Avatar
Transmission: 5 spd
Yeah, I was just referring to it bouncing all over the place because of the computer making adjustments, and how my car left it's computer at the assembly line...
Old Feb 10, 2005 | 10:49 PM
/\/3\/\/l8l3's Avatar
I had one on my carbed nova, it was ONLY accurate at idle it seemed, the a/f on dyno showed a HUGE difference over the gauge.
I had a autometer gauge
Old Feb 11, 2005 | 12:14 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
The a/f guage is always going to bounce around. I have one right now and im carb non computer controlled. It hunts around when u are just cruising or idleing put when u are on it holds steady. So it gets the job done only at WOT. A wideband is the only way to keep it from bouncing all over the place. But on a carb car it will move the least since the carb really cant adjust as much like a computer can.
Old Feb 11, 2005 | 12:23 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which is where it's least accurate too.
Old Feb 11, 2005 | 12:26 AM
305q_ta86's Avatar
Transmission: 5 spd
Hmm.. I'm getting the feeling that it would be a good idea to skip the gauge and find a better way to tune it...
Old Feb 11, 2005 | 12:46 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Best way is to dyno tune it with a wideband or buy a wideband. As far as dyno tuning most shops around here charge in the 500 range to fully dyno tune a car. So if u are going to keep changing things and u want to be precise by a wideband if u search u can find some in the 3-400 range.
Old Feb 11, 2005 | 12:53 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
If your in a budget which most of us are just buy and a/f guage it will let u know if your running rich or lean it just won be exact but its better than tuning blind.
Old Feb 11, 2005 | 12:56 AM
305q_ta86's Avatar
Transmission: 5 spd
True that. my fuel consumption sucks, though that may just be due to my driving.
Old Feb 11, 2005 | 12:57 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It will only tell if you're rich or lean compared to stoich, which isn't all that useful for tuning from a performance point of view.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
