Crazy theory/idea on MAF intake
Old Jun 25, 2001 | 02:17 PM
R.O.B.'s Avatar
OK, we all know that the MAF is a restriction. But if I'm not mistaken, at WOT, this sensor is not used. So here is my crazy idea:
Run a Y-pipe off the intake. One half is connected to the MAF, then to the filter, just like normal. The second half is connected to a solenoid activted throttle-body like blade, then to a filter. Under normal driving, the car would operate like normal, when you mash the pedal to WOT, a switch would activate the solenoid, allowing extra filtered air to come in. This would allow more CFM's then the MAF would normally be able to flow.
Is this a B.S. idea? Is this possible? I want everyone thoughts, ideas, or improvements.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Jun 25, 2001 | 03:58 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
It'd be a neat idea except the MAF is used at WOT.
Old Jun 25, 2001 | 06:32 PM
R.O.B.'s Avatar
Oh, I thought it wasn't used at WOT, I thought the ECM went into pre-programed open loop mode at WOT.
Old Jun 25, 2001 | 06:37 PM
IROC-Z_85's Avatar
I *think* R.O.B is right
I know your O2 isn't used at WOT
1985 IROC-Z, nuff said :P
Old Jun 25, 2001 | 06:58 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
MAF is most assuredly used at WOT.
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, K+N cone, AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, ARAP, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
Old Jun 25, 2001 | 07:00 PM
Bort62's Avatar
ed ed ed...
lol
Sorta hard to measure incoming air to meter fuel w/o a MAF at WOT....
considering WOT 5500 rpm and 2000 RPM will register very differnt gram/sec
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
92projectcamaro
Jan 18, 2016 08:00 AM
86iroczwv
Sep 3, 2015 06:21 PM
z28guy134
Sep 1, 2015 11:50 PM
trevor1010
Aug 24, 2015 11:29 AM
Bert87
Aug 23, 2015 03:50 PM
