SLP runners installation?
Old Feb 7, 2005 | 10:33 AM
1988 Massz's Avatar
Car: Acura now/Z in the summer
Engine: 5.7 tpi
Hi just a quick question well I removed my stock upper intake the otherday and removed the gaskets and I cleaned up the gasket surfaces and smoothed them out. I am just awaiting my slp runners and look forward to getting them to install. My only question is that I have heard they are an easy bolt on but, I just wanted to know what all you guys think about them or anything I should know before installation?
Old Feb 7, 2005 | 11:12 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
They are a helluva a lot easier than the AS&M large tubes. I didn't have a problem installing the SLP ones when I had 'em.
Old Feb 7, 2005 | 07:14 PM
Clutch_Grabwell's Avatar
Car: 1986 Monte Carlo SS
Engine: 1989 L98
Axle/Gears: 8.5" 3.42:1 posi
The longer bolts from the stock runners will probably be too short. I'm using a mix of original Torx bolts and allen head screws to mount my SLP runners. The heads on the inside bolts needed their OD ground down a bit as well.
http://pic5.picturetrail.com/VOL87/5...0/76222935.jpg
Go Wormtown! (Tatnuck Square native.)
Old Feb 8, 2005 | 07:09 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have had no problems with my SLP runners. I'm currently modifying them and port matching. Allen
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
mdtoren
Aug 23, 2015 12:52 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
mdtoren
Aug 16, 2015 05:45 PM
