A/C Bracket problems
Old Jun 24, 2001 | 08:04 PM
pstrokerjr's Avatar
I recently purchased an '87 Formula that had a 350 swapped in place of the carburated 305. The previous owner had everything back together except for the A/C system. While hooking the A/C back up, I've run into a problem. I can't seem to get the stock A/C bracket to fit. Does the 350 use a different bracket than the 305? If not, is there any special trick to it or am I just blind? Any info would be greatly appreciated.
Old Jun 25, 2001 | 09:46 PM
SUPER-SPORT-CHEVY's Avatar
Well to answer as much as possible.
The 350 has the same holes for the ac as the 305. One problem, If the guy installed heads with no acsesory holes. there should be 3 holes on each side to allow for ac. Dunno you might just be blink"J/K"
SSC
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Genopsyde
Nov 11, 2015 10:46 PM
