only 1 tire spins in a burnout
Old Jun 25, 2001 | 02:16 PM
Trent257's Avatar
why does my car do that?
Trent
89 Firebird
305 v8 TBI
automatic
t-tops
Old Jun 25, 2001 | 02:18 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
You probably don't have posi-traction which means you have an open rearend. I believe most cars besides the Z28's came with open rearends. Someone please correct me if i'm wrong.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Jun 25, 2001 | 02:19 PM
R.O.B.'s Avatar
Sounds like you have whats known as an open diff. If you want both to spin, get a posi.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Jun 25, 2001 | 08:31 PM
Jason86Z28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by branz28:
</font>
Even the Z's came w/ open rears my 86 is open...
1986 Z28 LG4 M5
Alpine 6x9's 2 10" MTX Thunder 4000's MTX Thunder 102 Amp Hooker Aero-Chamber Cat-Back
Old Jun 25, 2001 | 08:58 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
One tire fire! Mine has posi.
Old Jun 25, 2001 | 10:22 PM
One Eyed Jack's Avatar
Peg-legged road runner
Old Jun 25, 2001 | 11:02 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
my 87 z28 doesnt have posi either . how hard would it be to switch it over to posi, and how much would it cost?
Old Jun 25, 2001 | 11:35 PM
Gta-Paladin's Avatar
When my diff was leaking i didnt get posi they topped up the liquid and tightened it now i've got it back
Old Jun 26, 2001 | 12:03 AM
Trent257's Avatar
thats ****ty, how much wold it cost to get a posi
Trent
89 Firebird
305 v8 TBI
automatic
t-tops
Old Jun 26, 2001 | 01:33 AM
Mo's Avatar
Mo
PowerTrax is like $300 from summit I think. It is one way to go, but I'm not sure what rears it works with.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
http://members.nbci.com/IrocZgarage/home.htm
Old Jun 26, 2001 | 12:32 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
89+ cars Slp's OEM Zexel $100 is the only way to go. LOVE MINE. No clutches and is the best posi I have driven. Personally hate the way lockers drive.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar
*Alston SFC's
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jun 26, 2001 | 01:06 PM
Cruising270's Avatar
My old 86 Sports Coupe Camaro with the 4brl was even POSI. (it was like the most low end V-8 Camaro) I thought all the Camaros where posi, I heard just most people clutches were worn thats the reason for the one tire burn outs.
Old Jun 26, 2001 | 01:48 PM
Bort62's Avatar
You need to be more careful who you listen too then.
Posi was far from standard Equipment. It is Just an option Like any other and came on some cars, and not On others.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -&gt; My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 26, 2001 | 02:32 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'd like to smack the clown that ordered my IROC. Every option available in 85, but no posi.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 26, 2001 | 02:35 PM
Bort62's Avatar
Rear windsheild Wiper ?
Old Jun 26, 2001 | 02:49 PM
82camaro's Avatar
Car: 82 camaro SC
Zexel is far from 'the only way to go' The 100 dollar unit was taken out of new firebirds/camaros because it was too weak. It doesn't end up being 100 bucks after you add axles(if you don't have 28 spline),ring and pinion(if you don't have 3 series gears), bearings, professional install to set up the gears. Powertrax works just fine around town, it's not a 'normal' locker and is easy to install. The gears, bearings, axles, etc... remain intact. Auburn and Eaton also have some 'limited slip' units as well.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jun 26, 2001 | 03:54 PM
BlackZee's Avatar
It's been my experience that good ol' american v-8's tend to have this problem(?) with spinning tires during acceleration! To answer your question, 82Camaro has given solid advice. Another option would be to aquire a used rearend with posi from another 3rd or 4th gen car and swap it with yours.
Old Jun 26, 2001 | 07:50 PM
Eddie's Avatar
Mine has limited slip(89rs 305tbi). When the burnout starts only the passenger side wheel is burning the the driver side wheel will kick a few seconds later. If you are racing spinning is great for kicks but who keeps it solid to the pavement will be the one that wins. Posi track will do this!!
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Thirdgen89GTA
Apr 11, 2016 02:07 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
